APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U
Quicklinx: 95ZJWS00 Mfr#: SMX2200HV
Type: UPS
Power Rating: 1980watt
£1,480.96 ex VAT
£1,777.15 inc VAT
Maximizes battery performance, life, and reliability through intelligent, precision charging. Protects connected loads from surges, spikes, lightning, and other power disturbances.
  • Intelligent battery management
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning
  • SmartSlot
    Customize UPS capabilities with management cards
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users
  • Scalable runtime
    Allows additional run time to be quickly added as needed
  • Auto recognition of external batteries
    UPS recognizes when external battery packs are attached and automatically adjusts runtime
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment
  • Sequenced network shutdown and reboot
    Customize network shutdown and reboot sequence of connected servers and UPSs
  • Multiple switched outlet groups
    Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
  • High frequency design
    Reduces or eliminates bulky transformers resulting in lighter units for ease of handling
  • StruxureWare Data Center Expert compatible
    Enables centralized management via StruxureWare Data Center Expert
APC Smart-UPS X 2200 Rack/Tower LCD - UPS - 1980 Watt - 2200 VA
UPS - rack-mountable / external
Rack Size
4U
38.64 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
1980 Watt / 2200 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 2 x IEC jumper , 2 x power IEC 60320 C19
Lead Acid
Batteries Qty
1
Run Time (Up To)
9.8 min at full load
RS-232, USB
43.2 cm x 48.3 cm x 17.8 cm
3-year warranty
P/N: AR3105W, AR3140G, AR3155W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4000MVX432, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A, SMX3000HVTUS, SMX3000LVUS, SRT1000RMXLA-NC
Height (Rack Units)
4U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 140 - 280 V
Frequency Provided
47 - 53 / 57 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V 47 - 53 / 57 - 63 Hz
Power Capacity
1980 Watt / 2200 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
645 Joules
Circuit Protection
Circuit breaker
Efficiency
98.1%
Quantity
1
Lead Acid
Run Time (Up To)
9.8 min at full load , 25.3 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x USB , 1 x RS-232 , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable , USB cable , Power cable 1.83 m
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), overload protection, cold-start function
CSA, C-Tick, GOST, UL 1449, UL 1778, VDE, IEC 60950, EN 50091-2, IRAM, RoHS, EN 50091-1, FCC Part 15 A, REACH
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
55 dBA
43.2 cm
48.3 cm
17.8 cm
38.64 kg
Shipping Width
58.6 cm
Shipping Depth
63.3 cm
Shipping Height
33 cm
Shipping Weight
47.73 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC2513, ACF001, ACF002, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR3814, AR4000MV, AR4000MVX429, AR4000MVX432, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A, SMX2000LVNC, SMX3000HVTUS, SMX3000LVUS, SRT1000RMXLA-NC
95ZJ APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.76
95ZJ APC Basic Rack-Mount PDU - power distribution strip In Stock £205.36
95ZJ APC 1U Horizontal Cable Organiser In Stock £56.26
95ZJ APC Pwr Cord, 16A, 200-240V, C19 to UK Plug In Stock £60.48
95ZJ APC Netshelter heavy duty shelf In Stock £143.52
95ZJ APC Rackmount Rail Kit In Stock £91.78
95ZJ APC Power cable - 2.4 m In Stock £85.56
95ZJ APC Rack PDU Basic Zero U 16A 208/230V In Stock £303.12
95ZJ APC 2-Post Mounting Kit for Smart-UPS In Stock £177.68
95ZJ APC 3Yr Extended Warranty SP In Stock £323.53
95ZJ APC Rack PDU Basic Zero U 32A 230V In Stock £329.18
95ZJ APC Temperature and Humidity Sensor In Stock £132.19
95ZJ APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £300.02
95ZJ APC Cable Managers (Qty 10) In Stock £36.89
95ZJ APC 2G Power distribution strip In Stock £648.30
95ZJ APC Rack PDU 2G METERED ZEROU In Stock £703.81
95ZJ APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,015.17
95ZJ APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £973.78
95ZJ APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £88.79
95ZJ APC Power Cord Locking C19 to C20 3.0m In Stock £70.24
95ZJ APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £55.39
95ZJ APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,498.11
95ZJ APC NetShelter Zero U Accessory Mounting Bracket In Stock £101.91
95ZJ APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £59.23
95ZJ APC Smart-UPS X 120V External Battery Pack Rack/Tower In Stock £676.33
95ZJ APC 1U Blanking Panel Kit In Stock £35.27
95ZJ APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.59
95ZJ APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £49.57
95ZJ APC Power Cable (pack of 6) 1.22m In Stock £90.09
95ZJ APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,713.65
95ZJ APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.10
95ZJ APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £132.63
95ZJ APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £104.96
95ZJ APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £647.80
95ZJ APC Replacement Battery Cartridge #143 In Stock £433.22
95ZJ APC Metered Rack PDU In Stock £880.85
95ZJ APC Switched Rack PDU AC 208-230 V Ethernet In Stock £757.30
95ZJ APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,113.73
95ZJ APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £63.47
95ZJ APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £682.35
95ZJ APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,280.30
95ZJ APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £163.71
95ZJ APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,325.53
95ZJ APC Rack PDU Basic 0U/1U 100-240V/ In Stock £84.59
95ZJ APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £466.12
Type: UPS
Brand: APC
Price Range Ex VAT: £1000 - £1500
