APC Smart-UPS X 1000VA
Quicklinx: 7BJ3WS00 Mfr#: SMX1000I
Type: UPS
Power Rating: 800Watt
More than 50 In Stock
£765.85 ex VAT
£919.02 inc VAT
Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys. Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Green mode
  • High frequency design
    Reduces or eliminates bulky transformers resulting in lighter units for ease of handling.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Intuitive LCD interface
  • Auto recognition of external batteries
    UPS recognizes when external battery packs are attached and automatically adjusts runtime.
  • Multiple switched outlet groups
    Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Scalable runtime
    Allows additional run time to be quickly added as needed.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Plug-and-Play external batteries
    Ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS.
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
  • Intelligent Card Slot
    Customize UPS capabilities with management cards.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS X 1000 Rack/Tower LCD - UPS - 800 Watt - 1000 VA
UPS - rack-mountable
Rack Size
2U
22.9 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
800 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13
Lead Acid
Run Time (Up To)
8.1 min at full load
RS-232, USB
43.2 cm x 49 cm x 8.9 cm
3-year warranty
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 285 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
47 - 63 Hz
Input Connectors
Output Voltage
AC 230 V 47 - 63 Hz
Power Capacity
800 Watt / 1000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
600 Joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
8.1 min at full load , 24.2 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x EPO (emergency power off) , 1 x management (RS-232) , 1 x USB
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external , USB cable - external , Power cable 1.8 m
Rack Mounting Kit
Included
Audible alarm, emergency power off, LCD display, noise filtering
C-Tick, UL 1449, VDE, EN 50091-2, RoHS Exemption 7b, RoHS, EN 50091-1, REACH
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
40 dBA
43.2 cm
49 cm
8.9 cm
22.9 kg
Shipping Width
58.9 cm
Shipping Depth
62 cm
Shipping Height
24.6 cm
Shipping Weight
27.3 kg
7BJ3 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.83
7BJ3 APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £50.78
7BJ3 APC Basic Rack-Mount PDU - power distribution strip In Stock £203.03
7BJ3 APC 1U Vertical Cable Organiser In Stock £125.78
7BJ3 APC 1U Horizontal Cable Organiser In Stock £55.57
7BJ3 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.28
7BJ3 APC Netshelter heavy duty shelf In Stock £141.58
7BJ3 APC - rack cable guide - 1U In Stock £52.53
7BJ3 APC Rackmount Rail Kit In Stock £91.35
7BJ3 APC Rack PDU Basic Zero U 16A 208/230V In Stock £295.63
7BJ3 APC Rack PDU Basic Zero U 32A 230V In Stock £340.37
7BJ3 APC Temperature and Humidity Sensor In Stock £132.56
7BJ3 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £296.69
7BJ3 APC Smart-UPS X-Series 48V Ext. Batt Pack Rack/Tower In Stock £665.29
7BJ3 APC Cable Managers (Qty 10) In Stock £36.99
7BJ3 APC 2G Power distribution strip In Stock £640.07
7BJ3 APC Rack PDU 2G METERED ZEROU In Stock £693.12
7BJ3 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £504.42
7BJ3 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £990.67
7BJ3 APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £976.20
7BJ3 APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.12
7BJ3 APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,503.58
7BJ3 APC NetShelter Zero U Accessory Mounting Bracket In Stock £66.51
7BJ3 APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £58.76
7BJ3 APC 1U Blanking Panel Kit In Stock £35.42
7BJ3 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.50
7BJ3 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.92
7BJ3 APC Power Cable (pack of 6) 1.22m In Stock £88.33
7BJ3 APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,703.48
7BJ3 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.29
7BJ3 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £134.48
7BJ3 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £105.93
7BJ3 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £631.16
7BJ3 APC Replacement Battery In Stock £237.35
7BJ3 APC Metered Rack PDU In Stock £839.12
7BJ3 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £760.50
7BJ3 APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,085.33
7BJ3 APC 1 Year Extended Warranty 2015-4037 In Stock £63.20
7BJ3 APC Service Pack 3 Year Warranty Extension In Stock £117.87
7BJ3 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £61.55
7BJ3 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £702.09
7BJ3 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,246.30
7BJ3 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,295.76
7BJ3 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £82.84
7BJ3 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £466.02
Type: UPS
Brand: APC
Price Range Ex VAT: £750 - £1000
