Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys. Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
High online efficiency
Reduces utility costs, generates less heat. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
High frequency design
Reduces or eliminates bulky transformers resulting in lighter units for ease of handling. -
Energy meter
Provides actual kilowatt hours of usage for energy conscious users. -
Predictive replace battery date
Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning. -
Intuitive LCD interface
Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys. -
Auto recognition of external batteries
UPS recognizes when external battery packs are attached and automatically adjusts runtime. -
Multiple switched outlet groups
Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding. -
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. -
Scalable runtime
Allows additional run time to be quickly added as needed. -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Plug-and-Play external batteries
Ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS. -
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment. -
Intelligent Card Slot
Customize UPS capabilities with management cards. -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature.
- APC Smart-UPS X 1000 Rack/Tower LCD - UPS - 800 Watt - 1000 VA
- UPS - rack-mountable
- Rack Size
- 2U
- 22.9 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 800 Watt / 1000 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 8 x power IEC 60320 C13
- Battery
- Lead Acid
- Run Time (Up To)
- 8.1 min at full load
- Networking
- RS-232, USB
- Black
- 43.2 cm x 49 cm x 8.9 cm
- 3-year warranty
- Height (Rack Units)
- 2U
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 285 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Provided
- 47 - 63 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V 47 - 63 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 600 Joules
- Circuit Protection
- Circuit breaker
- Technology
- Lead Acid
- Run Time (Up To)
- 8.1 min at full load , 24.2 min at half load
- Recharge Time
- 3 hours
- Remote Management Interface
- RS-232, USB
- 1 x EPO (emergency power off) , 1 x management (RS-232) , 1 x USB
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- Serial cable - external , USB cable - external , Power cable 1.8 m
- Rack Mounting Kit
- Included
- Audible alarm, emergency power off, LCD display, noise filtering
- C-Tick, UL 1449, VDE, EN 50091-2, RoHS Exemption 7b, RoHS, EN 50091-1, REACH
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 40 dBA
- 43.2 cm
- 49 cm
- 8.9 cm
- 22.9 kg
- Shipping Width
- 58.9 cm
- Shipping Depth
- 62 cm
- Shipping Height
- 24.6 cm
- Shipping Weight
- 27.3 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £28.44 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £49.76 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £200.40 |
APC 1U Vertical Cable Organiser | In Stock | £121.73 |
APC 1U Horizontal Cable Organiser | In Stock | £52.80 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £52.63 |
APC - rack cable guide - 1U | In Stock | £51.13 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £296.06 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £312.30 |
APC Temperature and Humidity Sensor | In Stock | £135.44 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £287.13 |
APC Smart-UPS X-Series 48V Ext. Batt Pack Rack/Tower | In Stock | £629.85 |
APC Cable Managers (Qty 10) | In Stock | £34.69 |
APC 2G Power distribution strip | In Stock | £644.88 |
APC Rack PDU 2G METERED ZEROU | In Stock | £698.19 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £966.94 |
APC 19" Rack LCD Console | In Stock | £1,386.96 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £81.14 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £66.29 |
APC 1U Blanking Panel Kit | In Stock | £34.02 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.18 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £47.80 |
APC Power Cable (pack of 6) 1.22m | In Stock | £85.91 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,604.72 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £69.43 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £131.40 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £636.55 |
APC Replacement Battery | In Stock | £232.84 |
APC Metered Rack PDU | In Stock | £826.88 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £729.00 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,086.64 |
APC 1 Year Extended Warranty 2015-4037 | In Stock | £61.04 |
APC Service Pack 3 Year Warranty Extension | In Stock | £107.47 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £61.12 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,142.25 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £666.78 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,255.36 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £161.91 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £83.18 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £469.27 |
