Smart-UPS VT offers centralized three-phase power protection with the reliability of the award winning Smart-UPS family. Ideal for small data centers, large retail stores, regional offices, and dense power requirements, the Smart-UPS VT includes dual-mains input, automatic and maintenance bypasses, and scalable runtime with hot-swappable batteries for increased availability. Low cost of ownership is achieved through best-in-class efficiency and a reduction in rating of electrical infrastructure - wires, transformers, and generators due the Smart-UPS VT's Soft Start feature. Serviceability is greatly enhanced by user-replaceable batteries. All these features make the Smart-UPS VT is the easiest UPS in its class to deploy, manage and maintain.
Parallel-capacity capable
Increases total power capacity by using multiple uninterruptible power supplies simultaneously -
Parallel-redundant capable
Power the connected equipment with multiple uninterruptible power supplies to increase system redundancy
- APC Smart-UPS VT 15kVA with 2 Battery Modules Expandable to 4 - UPS - 12 kW - 15000 VA
- UPS - external
- 415 kg
- Input Wiring
- 3-phase
- Input Voltage
- AC 380/400/415 V
- Output Voltage
- AC 380/400/415 V ± 5%
- Power Capacity
- 12 kW / 15000 VA
- Input Connectors
- 1 x hardwire 5-wire (3PH + N + G)
- Output connectors
- 1 x Terminal Block (Screw) , 1 x hardwire 5-wire (3PH + N + G) , 1 x hardwire 4-wire (3PH + G)
- Battery
- Lead Acid expandable
- Battery Form Factor
- Internal
- Batteries Qty
- 2 (installed) / 4 (supported)
- Run Time (Up To)
- 9.7 min at full load
- Networking
- Ethernet 10/100, RS-232
- Remote Management Protocol
- SNMP, HTTP, HTTPS, WAP
- Black
- 55.9 cm x 81.3 cm x 150 cm
- 1-year warranty
- UPS - external
- Battery Enclosure Type
- Internal
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 380/400/415 V
- Input Voltage Range
- AC 304 - 477 V
- Frequency Provided
- 47 - 53 Hz
- Input Wiring
- 3-phase
- Frequency Required
- 47 - 70 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 380/400/415 V ± 5% - 47 - 53 Hz
- Power Capacity
- 12 kW / 15000 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Circuit Protection
- Circuit breaker
- Expandable
- Quantity
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 5 hours
- Remote Management Interface
- 1 x management (Ethernet) - RJ-45 , 1 x EPO (emergency power off) , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
- Expansion Slots
- 1 (total) / 0 (free) x SmartSlot
- Audible alarm, emergency power off, LCD display, built-in maintenance bypass, built-in static bypass
- C-Tick, ISO 9001, IEC 61000-3-2, IEC 61000-3-3, ISO 14001, EN 50091-2, IEC 62040-3
- Software Included
- Drivers & Utilities
- Limited warranty - 1 year , Installation
- 0 °C
- 40 °C
- Sound Emission
- 64 dBA
- 55.9 cm
- 81.3 cm
- 150 cm
- 415 kg
- Shipping Width
- 65 cm
- Shipping Depth
- 106 cm
- Shipping Height
- 164 cm
