APC Smart-UPS SRT UPS 4500 Watt 5000 VA
Quicklinx: BY6GWS00 Mfr#: SRT5KXLI
Power Rating: 4500Watt
£3,888.49 ex VAT
£4,666.18 inc VAT
LCD graphics display has text and mimic diagrams that display modes of operation, system parameters and alarms. Connect the device to a network using a 10 or 100 BASE-T connection. Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Battery failure notification provides early-warning fault analysis on batteries enabling timely preventive maintenance. Automatic internal bypass supplies utility power to the connected loads in the event of a UPS power overload or fault. Scalable runtime allows additional run time to be quickly added as needed. Intelligent battery management maximizes battery performance, life, and reliability through intelligent, precision charging.
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • 10/100 BaseT connection
    Connect the device to a network using a 10 or 100 BaseT connection
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
APC Smart-UPS SRT 5000VA - UPS - 4500 Watt - 5000 VA
UPS - rack-mountable / external
Rack Size
3U
54.55 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
4500 Watt / 5000 VA
Input Connectors
1 x hardwire 3-wire (1PH + N + G)
Output connectors
6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 2 x IEC connector
Lead Acid
Run Time (Up To)
4 min at full load
Ethernet 10/100, USB
13 cm x 71.9 cm x 43.2 cm
3-year warranty
P/N: SRT10KXLTUS, SRT1500RMXLA-NC, SRT1500XLA, SRT192BPUS, SRT192RMBP2US, SRT192RMBPM, SRT192RMBPUS, SRT2200RMXLA, SRT2200RMXLA-NC, SRT2200RMXLAUS, SRT2200XLA, SRT3000RMXLA, SRT3000RMXLA-NC, SRT3000RMXLT-NC, SRT3000XLA, SRT3000XLAUS, SRT5KXLTUS, SRT6KXLTUS, SRT72RMBPUS, SRT8KXLTUS, SRT96RMBPUS
Height (Rack Units)
3U
UPS Technology
On-line
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
4500 Watt / 5000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Efficiency
98%
Lead Acid
Run Time (Up To)
4 min at full load , 11.8 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Audible alarm, LCD display
C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years ¦ Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
13 cm
71.9 cm
43.2 cm
54.55 kg
Shipping Width
61 cm
Shipping Depth
96 cm
Shipping Height
33 cm
Shipping Weight
63.5 kg
P/N: SRT1000RMXLA, SRT1000XLA, SRT10KRMXLT-10KTF, SRT10KRMXLT30, SRT10KRMXLT-5KTF2, SRT10KRMXLT-IEC, SRT10KXLT, SRT10KXLT30, SRT10KXLT-5KTF2, SRT10KXLT-IEC, SRT10KXLTUS, SRT1500RMXLA-NC, SRT1500XLA, SRT192BP, SRT192BPUS, SRT192RMBP, SRT192RMBP2, SRT192RMBP2US, SRT192RMBPM, SRT192RMBPUS, SRT2200RMXLA, SRT2200RMXLA-NC, SRT2200RMXLAUS, SRT2200XLA, SRT3000RMXLA, SRT3000RMXLA-NC, SRT3000RMXLT, SRT3000RMXLT-5KTF, SRT3000RMXLT-NC, SRT3000RMXLW-IEC, SRT3000XLA, SRT3000XLAUS, SRT3000XLT, SRT3000XLT-5KTF, SRT3000XLW-IEC, SRT5KRMXLT-5KTF, SRT5KRMXLT-IEC, SRT5KRMXLW-HW, SRT5KXLT, SRT5KXLT-5KTF, SRT5KXLT-IEC, SRT5KXLTUS, SRT6KRMXLT, SRT6KRMXLT-5KTF, SRT6KXLT, SRT6KXLT-5KTF, SRT6KXLT-IEC, SRT6KXLTUS, SRT72BP, SRT72RMBP, SRT72RMBPUS, SRT8KRMXLT, SRT8KRMXLT30, SRT8KRMXLT-5KTF, SRT8KXLT, SRT8KXLT30, SRT8KXLT-5KTF, SRT8KXLT-IEC, SRT8KXLTUS, SRT96BP, SRT96RMBP, SRT96RMBPUS
BY6G APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £29.66
BY6G APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £49.65
BY6G APC - Power cable - Male-Female - 1.98 m In Stock £48.33
BY6G APC Basic Rack-Mount PDU - power distribution strip In Stock £200.45
BY6G APC Power cable - 2.4 m In Stock £84.90
BY6G APC Rack PDU Basic Zero U 16A 208/230V In Stock £295.51
BY6G APC Temperature and Humidity Sensor In Stock £133.76
BY6G APC POWER CORD C13 TO C20 1.98m Black In Stock £51.64
BY6G APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £285.58
BY6G APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £84.34
BY6G APC Power Cord Locking C19 to C20 3.0m In Stock £69.55
BY6G APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £52.20
BY6G APC Service Pack 3 Year Warranty Extension (for new purchases) In Stock £522.21
BY6G APC Smart-UPS SRT 192V 5kVA and 6kVA Battery Pack In Stock £1,302.60
BY6G APC Power Cable (pack of 6) 1.22m In Stock £85.93
BY6G APC Dry Contact I/O SmartSlot Card In Stock £173.03
BY6G APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £130.91
BY6G APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh In Stock £574.84
BY6G APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £632.28
BY6G APC Extended Warranty Renewal Technical Support (Renewal) 3 Years In Stock £736.09
BY6G APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA In Stock £225.11
BY6G APC Smart-UPS SRT 72V 2.2kVA RM Battery Pack Battery Enclosure In Stock £934.99
BY6G APC Smart-UPS SRT 96V 3kVA RM Battery Pack - Lead Acid In Stock £1,193.70
BY6G APC Smart-UPS SRT 192V 8 and 10kVA RM Battery Pack In Stock £1,614.57
BY6G APC Switched Rack PDU AC 208-230 V Ethernet In Stock £729.17
BY6G APC Smart-UPS SRT 72V 2.2kVA Battery Pack In Stock £764.19
BY6G APC Smart-UPS SRT 96V 3kVA Battery Pack In Stock £1,200.86
BY6G APC Service Pack 1 Year Warranty Extension In Stock £233.14
BY6G APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £61.22
BY6G APC Switched PDU 10A 0U C13x16 In Stock £1,162.48
BY6G APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £656.65
BY6G APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,256.51
BY6G APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £161.52
BY6G APC Rack PDU Basic 0U/1U 100-240V/ In Stock £81.29
BY6G APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £466.72
Brand: APC
Price Range Ex VAT: £1500+
