LCD graphics display has text and mimic diagrams that display modes of operation, system parameters and alarms. Connect the device to a network using a 10 or 100 BASE-T connection. Green mode bypasses unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection. Battery failure notification provides early-warning fault analysis on batteries enabling timely preventive maintenance. Automatic internal bypass supplies utility power to the connected loads in the event of a UPS power overload or fault. Scalable runtime allows additional run time to be quickly added as needed. Intelligent battery management maximizes battery performance, life, and reliability through intelligent, precision charging.
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection -
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Text and mimic diagrams that display modes of operation, system parameters and alarms -
ECO Mode
Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection -
10/100 BaseT Connection
Connect the device to a network using a 10 or 100 BaseT connection
- APC Smart-UPS SRT 5000VA RM - UPS - 4500 Watt - 5000 VA
- UPS - rack-mountable
- Rack Size
- 3U
- 54.55 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 3%
- Power Capacity
- 4500 Watt / 5000 VA
- Input Connectors
- Hardwire 3-wire (1PH + N + G)
- Output connectors
- 6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 2 x IEC connector
- Battery
- Lead Acid
- Run Time (Up To)
- 4 min at full load
- Networking
- USB
- Black
- 43.2 cm x 71.9 cm x 13 cm
- 3-year warranty
- Designed For
- P/N: ACDC2513, AR2407, AR2480, AR2487, AR2487G, AR2507, AR2580, AR2587, AR3100G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3300G, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, NBWL0356A
- Height (Rack Units)
- 3U
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 230 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 45 - 65 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 3% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 480 Joules
- Efficiency
- 98%
- Technology
- Lead Acid
- Run Time (Up To)
- 4 min at full load , 11.8 min at half load
- Recharge Time
- 3 hours
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- USB
- 1 x serial - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Audible alarm, LCD display
- C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Sound Emission
- 55 dBA
- 43.2 cm
- 71.9 cm
- 13 cm
- 54.55 kg
- Shipping Width
- 61 cm
- Shipping Depth
- 96 cm
- Shipping Height
- 33 cm
- Shipping Weight
- 63.6 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC2513, ACF001, ACF002, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR2407, AR2480, AR2487, AR2487G, AR2507, AR2580, AR2587, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR8135BLK, NBWL0356A
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £28.19 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £49.31 |
APC - Power cable - Male-Female - 1.98 m | In Stock | £49.05 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £203.09 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £52.40 |
APC Power cable - 2.4 m | In Stock | £83.05 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £293.40 |
APC Temperature and Humidity Sensor | In Stock | £133.44 |
APC POWER CORD C13 TO C20 1.98m Black | In Stock | £51.35 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £285.33 |
APC Power Cord Locking C19 to IEC309-16A 3.0m | In Stock | £83.79 |
APC Power Cord Locking C19 to C20 3.0m | In Stock | £68.95 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £51.94 |
APC Service Pack 3 Year Warranty Extension (for new purchases) | In Stock | £520.64 |
APC Smart-UPS SRT 192V 5kVA and 6kVA Battery Pack | In Stock | £1,233.00 |
APC Power Cable (pack of 6) 1.22m | In Stock | £85.46 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £130.23 |
APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh | In Stock | £577.48 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £630.87 |
APC Extended Warranty Renewal Technical Support (Renewal) 3 Years | In Stock | £761.54 |
APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA | In Stock | £224.44 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £740.02 |
APC Service Pack 1 Year Warranty Extension | In Stock | £237.01 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £60.82 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,132.04 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £666.42 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,248.14 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £160.46 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £82.43 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £465.61 |
