APC Smart-UPS SRT 8000VA 230V
Quicklinx: 9M1YWS00 Mfr#: SRT8KXLI
Type: UPS
Power Rating: 8000Watt
£5,741.02 ex VAT
£6,889.22 inc VAT
Provides pure sine wave output which is recommended by server manufacturers using active power factor corrected (PFC) power supplies. Safety agency tested and approved means that you can deploy Smart-UPS with confidence that they meet or exceed the industry's most rigorous standards.
Network grade power conditioning protects from damaging surges and disruptive noise. The double conversion architecture provides tight voltage regulation, frequency regulation, and zero transfer time to battery during power events.
Intelligent battery management, pioneered by APC, maximizes battery performance and life through intelligent, precision temperature compensated charging. Automatic self tests insure battery reliability and warn customers in advance of battery replacement. Convenient, easy to connect, hot-swappable battery modules provide battery replacement without powering down.
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • 10/100 BaseT connection
    Connect the device to a network using a 10 or 100 BaseT connection
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
APC Smart-UPS SRT 8000VA - UPS - 8000 Watt - 8000 VA
UPS - rack-mountable / external
Rack Size
6U
111.82 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
8000 Watt / 8000 VA
Input Connectors
Hardwire 5-wire (3PH + N + G), hardwire 3-wire (1PH + N + G)
Output connectors
6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 1 x hardwire 3-wire (HN + G) , 3 x IEC connector
Lead Acid
Run Time (Up To)
5.3 min at full load
Ethernet 10/100, USB
26.3 cm x 71.5 cm x 43.2 cm
3-year warranty
Height (Rack Units)
6U
UPS Technology
On-line
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
8000 Watt / 8000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Efficiency
98%
Lead Acid
Run Time (Up To)
5.3 min at full load , 14.8 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Audible alarm, LCD display
C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
26.3 cm
71.5 cm
43.2 cm
111.82 kg
Shipping Width
60 cm
Shipping Depth
100 cm
Shipping Height
46.1 cm
Shipping Weight
126.82 kg
9M1Y APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £28.90
9M1Y APC - Power cable - Male-Female - 1.98 m In Stock £47.79
9M1Y APC Basic Rack-Mount PDU - power distribution strip In Stock £197.72
9M1Y APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £50.88
9M1Y APC Pwr Cord, 16A, 200-240V, C19 to UK Plug In Stock £56.28
9M1Y APC Power cable - 2.4 m In Stock £82.25
9M1Y APC Rack PDU Basic Zero U 16A 208/230V In Stock £286.90
9M1Y C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
9M1Y C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.73
9M1Y APC Temperature and Humidity Sensor In Stock £133.79
9M1Y APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £271.25
9M1Y APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £953.12
9M1Y APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £85.03
9M1Y APC Power Cord Locking C19 to C20 3.0m In Stock £66.28
9M1Y APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £51.95
9M1Y APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £56.28
9M1Y APC Power Cable (pack of 6) 1.22m In Stock £84.43
9M1Y APC Dry Contact I/O SmartSlot Card In Stock £165.13
9M1Y APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £126.10
9M1Y APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh In Stock £565.88
9M1Y APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £100.67
9M1Y APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £614.64
9M1Y APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA In Stock £212.96
9M1Y APC Smart-UPS SRT 192V 8 and 10kVA RM Battery Pack In Stock £1,524.38
9M1Y APC Switched Rack PDU AC 208-230 V Ethernet In Stock £731.73
9M1Y APC Service Pack 3 Year Warranty Extension In Stock £975.99
9M1Y APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £59.34
9M1Y APC Switched PDU 10A 0U C13x16 In Stock £1,129.15
9M1Y APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £668.72
9M1Y APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,217.48
9M1Y APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £155.82
9M1Y APC Rack PDU Basic 0U/1U 100-240V/ In Stock £80.21
Type: UPS
Brand: APC
Price Range Ex VAT: £1500+
