Provides pure sine wave output which is recommended by server manufacturers using active power factor corrected (PFC) power supplies. Safety agency tested and approved means that you can deploy Smart-UPS with confidence that they meet or exceed the industry's most rigorous standards.
Network grade power conditioning protects from damaging surges and disruptive noise. The double conversion architecture provides tight voltage regulation, frequency regulation, and zero transfer time to battery during power events.
Intelligent battery management, pioneered by APC, maximizes battery performance and life through intelligent, precision temperature compensated charging. Automatic self tests insure battery reliability and warn customers in advance of battery replacement. Convenient, easy to connect, hot-swappable battery modules provide battery replacement without powering down.
LCD graphics display
Text and mimic diagrams that display modes of operation, system parameters and alarms. -
10/100 BaseT connection
Connect the device to a network using a 10 or 100 BaseT connection -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance
- APC Smart-UPS SRT 8000VA - UPS - 8000 Watt - 8000 VA
- UPS - rack-mountable / external
- Rack Size
- 6U
- 111.82 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 3%
- Power Capacity
- 8000 Watt / 8000 VA
- Input Connectors
- Hardwire 5-wire (3PH + N + G), hardwire 3-wire (1PH + N + G)
- Output connectors
- 6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 1 x hardwire 3-wire (HN + G) , 3 x IEC connector
- Battery
- Lead Acid
- Run Time (Up To)
- 5.3 min at full load
- Networking
- Ethernet 10/100, USB
- Black
- 26.3 cm x 71.5 cm x 43.2 cm
- 3-year warranty
- Height (Rack Units)
- 6U
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 230 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 45 - 65 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 3% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 480 Joules
- Efficiency
- 98%
- Technology
- Lead Acid
- Run Time (Up To)
- 5.3 min at full load , 14.8 min at half load
- Recharge Time
- 3 hours
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- 1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Audible alarm, LCD display
- C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Sound Emission
- 55 dBA
- 26.3 cm
- 71.5 cm
- 43.2 cm
- 111.82 kg
- Shipping Width
- 60 cm
- Shipping Depth
- 100 cm
- Shipping Height
- 46.1 cm
- Shipping Weight
- 126.82 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £29.76 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £49.49 |
APC - Power cable - Male-Female - 1.98 m | In Stock | £49.24 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £199.36 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £52.59 |
APC Power cable - 2.4 m | In Stock | £83.05 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £294.53 |
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.75 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.87 |
APC Temperature and Humidity Sensor | In Stock | £131.36 |
APC POWER CORD C13 TO C20 1.98m Black | In Stock | £51.35 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £284.90 |
APC Power Cord Locking C19 to IEC309-16A 3.0m | In Stock | £84.10 |
APC Power Cord Locking C19 to C20 3.0m | In Stock | £68.95 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £51.93 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £58.03 |
APC Power Cable (pack of 6) 1.22m | In Stock | £85.46 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £130.76 |
APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh | In Stock | £587.80 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £630.78 |
APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA | In Stock | £225.29 |
APC Smart-UPS SRT 192V 8 and 10kVA RM Battery Pack | In Stock | £1,625.03 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £739.43 |
APC Service Pack 3 Year Warranty Extension | In Stock | £1,003.53 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £59.64 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,159.17 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £653.11 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,245.58 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £157.34 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £82.70 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £465.61 |
