Provides pure sine wave output which is recommended by server manufacturers using active power factor corrected (PFC) power supplies. Safety agency tested and approved means that you can deploy Smart-UPS with confidence that they meet or exceed the industry's most rigorous standards.
Network grade power conditioning protects from damaging surges and disruptive noise. The double conversion architecture provides tight voltage regulation, frequency regulation, and zero transfer time to battery during power events.
Intelligent battery management, pioneered by APC, maximizes battery performance and life through intelligent, precision temperature compensated charging. Automatic self tests insure battery reliability and warn customers in advance of battery replacement. Convenient, easy to connect, hot-swappable battery modules provide battery replacement without powering down.
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
- APC Smart-UPS SRT 72V 2.2kVA Battery Pack - battery enclosure - Lead Acid
- Battery enclosure - external
- 33.9 kg
- Battery
- Lead Acid
- Batteries Qty
- 2
- Black
- 8.5 cm x 59.4 cm x 43.2 cm
- 3-year warranty
- Designed For
- P/N: SRT10KRMXLI, SRT10KXLI, SRT10RMXLIX806, SRT2200XLA, SRT2200XLI, SRT2200XLI-KR, SRT5KXLI, SRT6KRMXLI, SRT6KRMXLI-6W, SRT6KRMXLIM, SRT6KXLI
- Black
- Quantity
- 2
- Technology
- Lead Acid
- Maintenance free, sealed, leak-proof
- RoHS, REACH
- Limited warranty - 3 years ¦ Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 8.5 cm
- 59.4 cm
- 43.2 cm
- 33.9 kg
- Shipping Width
- 59.9 cm
- Shipping Depth
- 83.1 cm
- Shipping Height
- 23.9 cm
- Shipping Weight
- 37.8 kg
- Designed For
APC Smart-UPS SRT UPS 4500 Watt 5000 VA | In Stock | £3,687.12 |
APC Smart-UPS SRT 19 INCH Rail Kit for SRT 2.2/3kVA | In Stock | £180.93 |
APC 1 Year Extended Warranty 2015-4037 | In Stock | £55.64 |
APC Service Pack 3 Year Warranty Extension | In Stock | £109.54 |
APC Replacement Battery Cartridge #141 | In Stock | £344.89 |
