Text and mimic diagrams that display modes of operation, system parameters and alarms.
Connect the device to a network using a 10 or 100 BaseT connection.
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
Provides early-warning fault analysis on batteries enabling timely preventive maintenance.
LCD graphics display
Text and mimic diagrams that display modes of operation, system parameters and alarms. -
10/100 BaseT connection
Connect the device to a network using a 10 or 100 BaseT connection -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Battery failure notification
- APC Smart-UPS SRT 6000VA - UPS - 6000 Watt - 6000 VA
- UPS - external
- 60 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 3%
- Power Capacity
- 6000 Watt / 6000 VA
- Input Connectors
- 1 x hardwire 3-wire (1PH + N + G)
- Output connectors
- 6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 1 x hardwire 3-wire (HN + G) , 2 x IEC connector
- Battery
- Lead Acid
- Run Time (Up To)
- 1.5 min at full load
- Networking
- Ethernet 10/100, USB
- Black
- 17.4 cm x 71.9 cm x 43.2 cm
- 3-year warranty
- Designed For
- P/N: SRT1500RMXLI-NC, SRT1500XLI
- UPS - external
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 230 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 45 - 65 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 3% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 480 Joules
- Efficiency
- 98%
- Technology
- Lead Acid
- Run Time (Up To)
- 1.5 min at full load , 8.1 min at half load
- Recharge Time
- 3 hours
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- 1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- USB cable - external
- Audible alarm, LCD display
- C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Sound Emission
- 55 dBA
- 17.4 cm
- 71.9 cm
- 43.2 cm
- 60 kg
- Shipping Width
- 61 cm
- Shipping Depth
- 96 cm
- Shipping Height
- 37 cm
- Shipping Weight
- 67 kg
- Designed For
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £28.90 |
APC - Power cable - Male-Female - 1.98 m | In Stock | £47.79 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £197.72 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £50.88 |
APC Pwr Cord, 16A, 200-240V, C19 to UK Plug | In Stock | £56.28 |
APC Power cable - 2.4 m | In Stock | £82.25 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £286.90 |
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £4.32 |
APC Temperature and Humidity Sensor | In Stock | £133.79 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £271.25 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £953.12 |
APC Power Cord Locking C19 to IEC309-16A 3.0m | In Stock | £82.34 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £51.95 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £56.28 |
APC Service Pack 3 Year Warranty Extension (for new purchases) | In Stock | £508.30 |
APC Smart-UPS SRT 192V 5kVA and 6kVA Battery Pack | In Stock | £1,265.42 |
APC Power Cable (pack of 6) 1.22m | In Stock | £84.43 |
APC Dry Contact I/O SmartSlot Card | In Stock | £165.13 |
APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh | In Stock | £565.88 |
APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £100.67 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £614.64 |
APC Extended Warranty Renewal Technical Support (Renewal) 3 Years | In Stock | £723.69 |
APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA | In Stock | £212.96 |
APC Smart-UPS SRT 72V 2.2kVA RM Battery Pack Battery Enclosure | In Stock | £921.36 |
APC Smart-UPS SRT 96V 3kVA RM Battery Pack - Lead Acid | In Stock | £1,193.70 |
APC Smart-UPS SRT 192V 8 and 10kVA RM Battery Pack | In Stock | £1,524.38 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £731.73 |
APC Smart-UPS SRT 72V 2.2kVA Battery Pack | In Stock | £760.28 |
APC Smart-UPS SRT 96V 3kVA Battery Pack | In Stock | £1,176.96 |
APC Service Pack 1 Year Warranty Extension | In Stock | £225.23 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £59.34 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,129.15 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £668.72 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,217.48 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £155.82 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £80.21 |
