APC SMART-UPS SRT 6000VA 230V
Quicklinx: BNB6WS00 Mfr#: SRT6KXLI
Power Rating: 6000watt
£4,627.90 ex VAT
£5,553.48 inc VAT
Text and mimic diagrams that display modes of operation, system parameters and alarms.
Connect the device to a network using a 10 or 100 BaseT connection.
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
Provides early-warning fault analysis on batteries enabling timely preventive maintenance.
  • LCD graphics display
  • 10/100 BaseT connection
  • Green mode
  • Battery failure notification
APC Smart-UPS SRT 6000VA - UPS - 6000 watt - 6000 VA
UPS - external
60 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
6000 watt / 6000 VA
Input Connectors
1 x hardwire 3-wire (1PH + N + G)
Output connectors
6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 1 x hardwire 3-wire (HN + G) , 2 x IEC connector
Lead Acid
Run Time (Up To)
1.5 min at full load
Ethernet 10/100, USB
17.4 cm x 71.9 cm x 43.2 cm
3-year warranty
P/N: SRT1500RMXLI-NC, SRT1500XLI
UPS - external
UPS Technology
On-line
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
6000 watt / 6000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 joules
Efficiency
98%
Lead Acid
Run Time (Up To)
1.5 min at full load , 8.1 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
Expansion Slots
1 (total) / 1 (free) x SmartSlot
USB cable - external
Audible alarm, LCD display
C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
17.4 cm
71.9 cm
43.2 cm
60 kg
Shipping Width
61 cm
Shipping Depth
96 cm
Shipping Height
37 cm
Shipping Weight
67 kg
BNB6 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.04
BNB6 APC Basic Rack-Mount PDU - power distribution strip In Stock £205.36
BNB6 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £54.43
BNB6 APC Power cable - 2.4 m In Stock £85.56
BNB6 APC Rack PDU Basic Zero U 16A 208/230V In Stock £303.12
BNB6 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
BNB6 APC Temperature and Humidity Sensor In Stock £132.19
BNB6 APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £973.78
BNB6 APC Power Cord Locking C19 to C20 3.0m In Stock £69.18
BNB6 APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £55.39
BNB6 APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £58.86
BNB6 APC Service Pack 3 Year Warranty Extension (for new purchases) In Stock £578.36
BNB6 APC Power Cable (pack of 6) 1.22m In Stock £90.09
BNB6 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £132.63
BNB6 APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh In Stock £591.71
BNB6 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £647.80
BNB6 APC Extended Warranty Renewal Technical Support (Renewal) 3 Years In Stock £829.90
BNB6 APC Smart-UPS SRT 72V 2.2kVA RM Battery Pack Battery Enclosure In Stock £970.83
BNB6 APC Smart-UPS SRT 192V 8 and 10kVA RM Battery Pack In Stock £1,640.61
BNB6 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £739.91
BNB6 APC Smart-UPS SRT 96V 3kVA Battery Pack In Stock £1,216.70
BNB6 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.58
BNB6 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £682.35
BNB6 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,280.30
BNB6 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £163.71
BNB6 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £466.12
Brand: APC
Price Range Ex VAT: £1500+
