Smart-UPS On-Line provides high density, true double-conversion on-line power protection for servers, voice / data networks, medical labs, and light industrial applications. Capable of supporting loads from 1 to 20kVA in a rack/tower convertible form, the Smart-UPS On-Line is available from 2U to 12U. Recent family extensions at 15 and 20kVA enable support of power hungry blade servers or heavily loaded equipment racks. When business-critical systems require runtime in hours, not minutes, Smart-UPS On-Line can be configured with matching battery packs to comply with aggressive runtime demands. The included PowerChute management software provides unattended graceful shutdown of network operating systems. All models 5kVA and above include an integrated Network Management Card for remote management (optional on models below 5 kVA). The Smart-UPS On-Line family provides customers with a reliable source of uninterruptible power even in demanding power environments, including very wide input voltage window, extremely tight output voltage regulation, frequency regulation, internal bypass, and input power factor correction.
LCD graphics display
Text and mimic diagrams that display modes of operation, system parameters and alarms. -
ECO Mode
Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
- APC Smart-UPS SRT 3000VA - UPS - 2700 Watt - 3000 VA
- UPS - external
- 31.3 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 3%
- Power Capacity
- 2700 Watt / 3000 VA
- Input Connectors
- Power IEC 60320 C20, power BS 1363A, Europlug (power CEE 7/16)
- Output connectors
- 8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
- Battery
- Lead Acid
- Run Time (Up To)
- 4 min at full load
- Networking
- RS-232, USB
- 8.5 cm x 63.5 cm x 43.2 cm
- Environmental Standards
- ENERGY STAR
- 3-year warranty
- UPS - external
- UPS Technology
- On-line
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 220 - 240 V
- Input Voltage Range (Adjustable)
- AC 100 - 275 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 40 - 70 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 3% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 340 Joules
- Technology
- Lead Acid
- Recharge Time
- 3 hours
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- RS-232, USB
- 1 x serial - RJ-45 , 1 x EPO (emergency power off) , 1 x management (USB)
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- 3 x power cable 2.44 m
- Audible alarm, emergency power off, LCD display, internal bypass
- VDE, IEC 62040-2, IP20, EAC, RCM, IEC 62040-1
- Software Included
- APC PowerChute Business Edition
Sustainability Information
- ENERGY STAR
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Sound Emission
- 55 dBA
- 8.5 cm
- 63.5 cm
- 43.2 cm
- 31.3 kg
- Shipping Width
- 59.9 cm
- Shipping Depth
- 87.1 cm
- Shipping Height
- 24.6 cm
- Shipping Weight
- 36.74 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £28.90 |
APC - Power cable - Male-Female - 1.98 m | In Stock | £47.79 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £197.72 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £50.88 |
APC Pwr Cord, 16A, 200-240V, C19 to UK Plug | In Stock | £56.28 |
APC Power cable - 2.4 m | In Stock | £82.25 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £286.90 |
APC 3Yr Extended Warranty SP | In Stock | £288.00 |
APC Temperature and Humidity Sensor | In Stock | £133.79 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £271.25 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £953.12 |
APC Power Cord Locking C19 to IEC309-16A 3.0m | In Stock | £82.34 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £51.95 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £56.28 |
APC Service Pack 3 Year Warranty Extension (for new purchases) | In Stock | £508.30 |
APC Power Cable (pack of 6) 1.22m | In Stock | £84.43 |
APC Dry Contact I/O SmartSlot Card | In Stock | £165.13 |
APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £100.67 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £614.64 |
APC Extended Warranty Renewal Technical Support (Renewal) 3 Years | In Stock | £723.69 |
APC Extended Warranty Service Pack Technical Support 1 Year | In Stock | £120.61 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £731.73 |
APC Smart-UPS SRT 96V 3kVA Battery Pack | In Stock | £1,176.96 |
APC Smart-UPS SRT 19 INCH Rail Kit for SRT 2.2/3kVA | In Stock | £168.17 |
APC Service Pack 1 Year Warranty Extension | In Stock | £225.23 |
APC Replacement battery cartridge #152 | In Stock | £570.62 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £59.34 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,129.15 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £668.72 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,217.48 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £155.82 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £80.21 |
