APC Smart-UPS SRT 3000VA UPS
Quicklinx: F1G2WS00 Mfr#: SRT3000XLI
Type: UPS
Power Rating: 2700watt
£2,666.39 ex VAT
£3,199.66 inc VAT
Smart-UPS On-Line provides high density, true double-conversion on-line power protection for servers, voice / data networks, medical labs, and light industrial applications. Capable of supporting loads from 1 to 20kVA in a rack/tower convertible form, the Smart-UPS On-Line is available from 2U to 12U. Recent family extensions at 15 and 20kVA enable support of power hungry blade servers or heavily loaded equipment racks. When business-critical systems require runtime in hours, not minutes, Smart-UPS On-Line can be configured with matching battery packs to comply with aggressive runtime demands. The included PowerChute management software provides unattended graceful shutdown of network operating systems. All models 5kVA and above include an integrated Network Management Card for remote management (optional on models below 5 kVA). The Smart-UPS On-Line family provides customers with a reliable source of uninterruptible power even in demanding power environments, including very wide input voltage window, extremely tight output voltage regulation, frequency regulation, internal bypass, and input power factor correction.
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • ECO Mode
    Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
APC Smart-UPS SRT 3000VA - UPS - 2700 watt - 3000 VA
UPS - external
31.3 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
2700 watt / 3000 VA
Input Connectors
Power IEC 60320 C20, power BS 1363A, Europlug (power CEE 7/16)
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid
Run Time (Up To)
4 min at full load
RS-232, USB
8.5 cm x 63.5 cm x 43.2 cm
Environmental Standards
ENERGY STAR
3-year warranty
P/N: SRT96RMBP
UPS - external
UPS Technology
On-line
Input Voltage
AC 230 V
Input Voltage Range
AC 220 - 240 V
Input Voltage Range (Adjustable)
AC 100 - 275 V
Frequency Provided
50/60 Hz
Frequency Required
40 - 70 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
2700 watt / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
340 joules
Lead Acid
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x serial - RJ-45 , 1 x EPO (emergency power off) , 1 x management (USB)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
3 x power cable 2.44 m
Audible alarm, emergency power off, LCD display, internal bypass
VDE, IEC 62040-2, IP20, EAC, RCM, IEC 62040-1
Software Included
APC PowerChute Business Edition
Sustainability Information
ENERGY STAR
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
8.5 cm
63.5 cm
43.2 cm
31.3 kg
Shipping Width
59.9 cm
Shipping Depth
87.1 cm
Shipping Height
24.6 cm
Shipping Weight
36.74 kg
P/N: SRT96RMBP
F1G2 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.45
F1G2 APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £51.81
F1G2 APC Basic Rack-Mount PDU - power distribution strip In Stock £205.78
F1G2 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.95
F1G2 APC Pwr Cord, 16A, 200-240V, C19 to UK Plug In Stock £59.85
F1G2 APC Rack PDU, Basic, Zero U, 10A,2 In Stock £279.25
F1G2 APC Rack PDU Basic Zero U 16A 208/230V In Stock £304.99
F1G2 APC 3Yr Extended Warranty SP In Stock £322.47
F1G2 APC Temperature and Humidity Sensor In Stock £130.54
F1G2 APC POWER CORD C13 TO C20 1.98m Black In Stock £53.18
F1G2 APC Power Cord Locking C19 to C20 3.0m In Stock £70.55
F1G2 APC Power Cord Kit (6 ea) Locking C19 to C20 1.2m In Stock £151.93
F1G2 APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £55.08
F1G2 APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £59.49
F1G2 APC Service Pack 3 Year Warranty Extension (for new purchases) In Stock £577.76
F1G2 APC Power Cable (pack of 6) 1.22m In Stock £90.04
F1G2 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £133.11
F1G2 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £103.89
F1G2 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £639.92
F1G2 APC Extended Warranty Renewal Technical Support (Renewal) 3 Years In Stock £819.81
F1G2 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £765.51
F1G2 APC Smart-UPS SRT 19 INCH Rail Kit for SRT 2.2/3kVA In Stock £178.64
F1G2 APC Service Pack 1 Year Warranty Extension In Stock £265.90
F1G2 APC Replacement battery cartridge #152 In Stock £592.11
F1G2 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.95
F1G2 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £683.92
F1G2 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,274.18
F1G2 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £164.46
F1G2 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £83.56
F1G2 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £466.62
Type: UPS
Brand: APC
Price Range Ex VAT: £1500+
