APC Smart-UPS SRT 3000VA RM Network Card
Quicklinx: F5HMWS00 Mfr#: SRT3000RMXLINC
More than 50 In Stock
£3,203.42 ex VAT
£3,844.10 inc VAT
Provides early-warning fault analysis on batteries enabling timely preventive maintenance. ECO mode by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection. Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Text and mimic diagrams display modes of operation, system parameters and alarms. Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • ECO Mode
    Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Battery failure notification
  • Rack/Tower convertible
APC Smart-UPS SRT 3000VA RM - UPS - 2700 watt - 3000 VA - Lead Acid - with APC UPS Network Management Card AP9641
UPS - rack-mountable / external
Rack Size
2U
31.3 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V
Power Capacity
2700 watt / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid Lead Acid
Run Time (Up To)
4 min at full load
RS-232, USB
Vertical stand
43.2 cm x 63.5 cm x 8.5 cm
Environmental Standards
ENERGY STAR
3-year warranty
Bundled with
P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150W, AR3155SP, AR3155W, AR3300W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
Height (Rack Units)
2U
Bundled with
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 275 V
Input Voltage Range (Adjustable)
AC 100 - 275 V
Frequency Provided
50/60 Hz
Frequency Required
40 - 70 Hz
Input Connectors
Output Voltage
AC 220/230/240 V 50/60 Hz
Power Capacity
2700 watt / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
340 joules
Efficiency
92%
Lead Acid Lead Acid
Run Time (Up To)
4 min at full load , 11.8 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x EPO (emergency power off) , 1 x management (USB) - 4 pin USB Type A
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Vertical stand
3 x power cable - external , USB cable - external , Network cable - external , Power extension cable - external , EPO cable
Rack Mounting Kit
Included
Audible alarm, LCD display, internal bypass, Eco-Mode
VDE, IEC 62040-2, RoHS, EN 62040-2, IP20, EAC, RCM, IEC 62040-1, EN 62040-1
Software Included
APC PowerChute Business Edition
Sustainability Information
ENERGY STAR
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
43.2 cm
63.5 cm
8.5 cm
31.3 kg
Shipping Width
59.9 cm
Shipping Depth
87.1 cm
Shipping Height
24.6 cm
Shipping Weight
39.92 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, NBWL0356A
F5HM APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.76
F5HM APC Basic Rack-Mount PDU - power distribution strip In Stock £204.71
F5HM APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £54.29
F5HM APC Power cable - 2.4 m In Stock £85.34
F5HM APC Rack PDU Basic Zero U 16A 208/230V In Stock £302.01
F5HM APC 3Yr Extended Warranty SP In Stock £322.69
F5HM APC Temperature and Humidity Sensor In Stock £132.19
F5HM APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £973.78
F5HM APC Power Cord Locking C19 to C20 3.0m In Stock £70.05
F5HM APC Power Cord Kit (6 ea) Locking C19 to C20 1.2m In Stock £153.80
F5HM APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £55.29
F5HM APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £59.73
F5HM APC Service Pack 3 Year Warranty Extension (for new purchases) In Stock £576.39
F5HM APC Power Cable (pack of 6) 1.22m In Stock £90.09
F5HM APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £131.99
F5HM APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £647.80
F5HM APC Extended Warranty Renewal Technical Support (Renewal) 3 Years In Stock £834.96
F5HM APC Extended Warranty Service Pack Technical Support 1 Year In Stock £138.73
F5HM APC Switched Rack PDU AC 208-230 V Ethernet In Stock £737.92
F5HM APC Smart-UPS SRT 19 INCH Rail Kit for SRT 2.2/3kVA In Stock £178.03
F5HM APC Replacement battery cartridge #152 In Stock £593.16
F5HM APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £63.36
F5HM APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £685.66
F5HM APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,274.19
F5HM APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £463.90
Brand: APC
Price Range Ex VAT: £1500+
