Provides pure sine wave output which is recommended by server manufacturers using active power factor corrected (PFC) power supplies. Safety agency tested and approved means that you can deploy Smart-UPS with confidence that they meet or exceed the industry's most rigorous standards.
Network manageable via serial, USB or optional Ethernet. Includes Powerchute Network Shutdown Software for convenient monitoring and control, safe operating system shutdown, and innovative energy management capabilities.
Network grade power conditioning protects from damaging surges and disruptive noise. The double conversion architecture provides tight voltage regulation, frequency regulation, and zero transfer time to battery during power events.
LCD graphics display
Text and mimic diagrams that display modes of operation, system parameters and alarms. -
ECO Mode
Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection. -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
- APC Smart-UPS SRT 2200VA - UPS - 1980 Watt - 2200 VA
- UPS - external
- 25 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 3%
- Power Capacity
- 1980 Watt / 2200 VA
- Input Connectors
- Power IEC 60320 C20, power BS 1363A, Europlug (power CEE 7/16)
- Output connectors
- 8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
- Battery
- Lead Acid
- Run Time (Up To)
- 3.9 min at full load
- Networking
- RS-232, USB
- 8.5 cm x 58.4 cm x 43.2 cm
- Environmental Standards
- ENERGY STAR
- 3-year warranty
- UPS - external
- UPS Technology
- On-line
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 220 - 240 V
- Input Voltage Range (Adjustable)
- AC 100 - 275 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 40 - 70 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 3% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 340 Joules
- Technology
- Lead Acid
- Recharge Time
- 3 hours
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- RS-232, USB
- 1 x serial - RJ-45 , 1 x EPO (emergency power off) , 1 x management (USB)
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- Power cable 2.44 m
- Audible alarm, emergency power off, LCD display, internal bypass
- VDE, IEC 62040-2, IP20, EAC, RCM, IEC 62040-1
- Software Included
- APC PowerChute Business Edition
Sustainability Information
- ENERGY STAR
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Sound Emission
- 55 dBA
- 8.5 cm
- 58.4 cm
- 43.2 cm
- 25 kg
- Shipping Width
- 59.9 cm
- Shipping Depth
- 81 cm
- Shipping Height
- 24.6 cm
- Shipping Weight
- 30.84 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £29.89 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £48.99 |
APC - Power cable - Male-Female - 1.98 m | In Stock | £50.90 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £202.03 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £52.81 |
APC Power cable - 2.4 m | In Stock | £84.15 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £299.80 |
APC 3Yr Extended Warranty SP | In Stock | £324.99 |
APC Temperature and Humidity Sensor | In Stock | £133.14 |
APC POWER CORD C13 TO C20 1.98m Black | In Stock | £52.05 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £287.81 |
APC Power Cord Locking C19 to IEC309-16A 3.0m | In Stock | £84.15 |
APC Power Cord Locking C19 to C20 3.0m | In Stock | £68.64 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £53.14 |
APC Power Cable (pack of 6) 1.22m | In Stock | £87.46 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £131.85 |
APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £101.73 |
APC Extended Warranty Service Pack Technical Support 1 Year | In Stock | £135.83 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £736.14 |
APC Smart-UPS SRT 19 INCH Rail Kit for SRT 2.2/3kVA | In Stock | £177.42 |
APC Replacement Battery Cartridge #141 | In Stock | £370.85 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £60.44 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,164.00 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £671.74 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,258.20 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £162.29 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £81.93 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £470.30 |
