APC Smart-UPS SRT 2200VA 230V
Quicklinx: CGXVWS00 Mfr#: SRT2200XLI
Power Rating: 1980Watt
£1,601.19 ex VAT
£1,921.42 inc VAT
Provides pure sine wave output which is recommended by server manufacturers using active power factor corrected (PFC) power supplies. Safety agency tested and approved means that you can deploy Smart-UPS with confidence that they meet or exceed the industry's most rigorous standards.
Network manageable via serial, USB or optional Ethernet. Includes Powerchute Network Shutdown Software for convenient monitoring and control, safe operating system shutdown, and innovative energy management capabilities.
Network grade power conditioning protects from damaging surges and disruptive noise. The double conversion architecture provides tight voltage regulation, frequency regulation, and zero transfer time to battery during power events.
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • ECO Mode
    Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
APC Smart-UPS SRT 2200VA - UPS - 1980 Watt - 2200 VA
UPS - external
25 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
1980 Watt / 2200 VA
Input Connectors
Power IEC 60320 C20, power BS 1363A, Europlug (power CEE 7/16)
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid
Run Time (Up To)
3.9 min at full load
RS-232, USB
8.5 cm x 58.4 cm x 43.2 cm
Environmental Standards
ENERGY STAR
3-year warranty
UPS - external
UPS Technology
On-line
Input Voltage
AC 230 V
Input Voltage Range
AC 220 - 240 V
Input Voltage Range (Adjustable)
AC 100 - 275 V
Frequency Provided
50/60 Hz
Frequency Required
40 - 70 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
1980 Watt / 2200 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
340 Joules
Lead Acid
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x serial - RJ-45 , 1 x EPO (emergency power off) , 1 x management (USB)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Power cable 2.44 m
Audible alarm, emergency power off, LCD display, internal bypass
VDE, IEC 62040-2, IP20, EAC, RCM, IEC 62040-1
Software Included
APC PowerChute Business Edition
Sustainability Information
ENERGY STAR
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
8.5 cm
58.4 cm
43.2 cm
25 kg
Shipping Width
59.9 cm
Shipping Depth
81 cm
Shipping Height
24.6 cm
Shipping Weight
30.84 kg
CGXV APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £29.76
CGXV APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £49.49
CGXV APC - Power cable - Male-Female - 1.98 m In Stock £49.24
CGXV APC Basic Rack-Mount PDU - power distribution strip In Stock £199.36
CGXV APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £52.59
CGXV APC Power cable - 2.4 m In Stock £83.05
CGXV APC Rack PDU Basic Zero U 16A 208/230V In Stock £294.53
CGXV APC 3Yr Extended Warranty SP In Stock £319.71
CGXV APC Temperature and Humidity Sensor In Stock £131.36
CGXV APC POWER CORD C13 TO C20 1.98m Black In Stock £51.35
CGXV APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £284.90
CGXV APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £84.10
CGXV APC Power Cord Locking C19 to C20 3.0m In Stock £68.95
CGXV APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £51.93
CGXV APC Power Cable (pack of 6) 1.22m In Stock £85.46
CGXV APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £130.76
CGXV APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £630.78
CGXV APC Extended Warranty Service Pack Technical Support 1 Year In Stock £124.01
CGXV APC Switched Rack PDU AC 208-230 V Ethernet In Stock £739.43
CGXV APC Smart-UPS SRT 19 INCH Rail Kit for SRT 2.2/3kVA In Stock £175.07
CGXV APC Replacement Battery Cartridge #141 In Stock £356.83
CGXV APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £59.64
CGXV APC Switched PDU 10A 0U C13x16 In Stock £1,159.17
CGXV APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £665.61
CGXV APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,245.58
CGXV APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £157.34
CGXV APC Rack PDU Basic 0U/1U 100-240V/ In Stock £82.70
CGXV APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £465.61
Brand: APC
Price Range Ex VAT: £1500+
