                Quick installationThe iBusway for Data Center solution uses bolted snap-fit hangers and plug-in joint connections, which simplify installation and eliminate the need for expensive special tools.
- APC - rack rail kit
- Product Type
- Rack rail kit
- 52.7 cm x 8.9 cm x 4.4 cm
- 2.72 kg
- 2-year warranty
- Designed For
- Smart-UPS SRT 2200VA, 3000VA
- Product Type
- Rack rail kit
- 52.7 cm
- 8.9 cm
- 4.4 cm
- 2.72 kg
- Limited warranty: - 2 years
- Designed For
- APC Smart-UPS SRT 2200VA, 3000VA
