APC SMART-UPS SRT 1000VA RM 230V
Quicklinx: GF08WS00 Mfr#: SRT1000RMXLI
Power Rating: 1000watt
11 In Stock
£1,072.55 ex VAT
£1,287.06 inc VAT
High density, double-conversion on-line power protection with scalable runtime.
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • ECO Mode
    Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
APC Smart-UPS SRT 1000VA RM - UPS - 1000 watt - 1000 VA
UPS - Power Factor Correction (PFC) - rack-mountable
Rack Size
2U
21 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V ± 2%
Power Capacity
1000 watt / 1000 VA
Input Connectors
1 x Europlug (power CEE 7/16), power BS 1363A, power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13
Lead Acid
Run Time (Up To)
8.5 min at full load
RS-232, USB
43.2 cm x 50.5 cm x 8.5 cm
Environmental Standards
ENERGY STAR
3-year warranty
Height (Rack Units)
2U
UPS Technology
On-line
Input Voltage
AC 230 V
Input Voltage Range
AC 50 - 150 / 80 - 150 V
Frequency Provided
50/60 Hz ± 3Hz
Frequency Required
40 - 70 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 2% - 50/60 Hz
Power Capacity
1000 watt / 1000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
432 joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
8.5 min at full load , 21.1 min at half load , 9.8 min at 900 Watts , 13.8 min at 700 Watts , 59.6 min at 200 Watts
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x management (RS-232) - RJ-45 , 1 x EPO (emergency power off) , 1 x management (USB)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Power cable 1.83 m , USB cable - external
Rack Mounting Kit
Included
LCD display, Eco-Mode, audible alarm, automatic self-test, cold-start function, reset breaker, LED indicators, internal bypass, hot-swappable batteries, firmware upgradable
REACH, RoHS, EAC, IP20
Software Included
APC PowerChute Business Edition
Sustainability Information
ENERGY STAR
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
50 dBA
43.2 cm
50.5 cm
8.5 cm
21 kg
Shipping Width
59.4 cm
Shipping Depth
74.9 cm
Shipping Height
24.6 cm
Shipping Weight
29.6 kg
GF08 APC Basic Rack-Mount PDU - power distribution strip In Stock £205.78
GF08 APC 1U Vertical Cable Organiser In Stock £125.77
GF08 APC 1U Horizontal Cable Organiser In Stock £55.58
GF08 APC Netshelter heavy duty shelf In Stock £145.67
GF08 APC Rackmount Rail Kit In Stock £89.40
GF08 APC Rack PDU, Basic, Zero U, 10A,2 In Stock £279.09
GF08 APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £209.55
GF08 APC Rack PDU Basic Zero U 16A 208/230V In Stock £304.83
GF08 APC Rack PDU Basic Zero U 32A 230V In Stock £328.60
GF08 APC Temperature and Humidity Sensor In Stock £130.54
GF08 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £293.94
GF08 APC Cable Managers (Qty 10) In Stock £36.45
GF08 APC Data Cbl part. passthru In Stock £114.46
GF08 APC 2G Power distribution strip In Stock £655.45
GF08 APC Rack PDU 2G METERED ZEROU In Stock £702.13
GF08 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £515.77
GF08 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,002.65
GF08 APC 19" Rack LCD Console In Stock £1,385.79
GF08 APC Vertical Cable Organizer, NetShelter SX, 42U In Stock £95.26
GF08 APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.60
GF08 APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,518.27
GF08 APC NetShelter Zero U Accessory Mounting Bracket In Stock £99.79
GF08 APC 1U Blanking Panel Kit In Stock £34.87
GF08 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.33
GF08 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.99
GF08 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.65
GF08 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £639.73
GF08 APC Metered Rack PDU In Stock £863.02
GF08 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £766.18
GF08 APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £268.27
GF08 APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,100.00
GF08 APC Smart-UPS SRT 19 INCH Rail Kit for SRT 2.2/3kVA In Stock £178.96
GF08 APC Service Pack 1 Year Warranty Extension In Stock £48.56
GF08 APC 1 Year Extended Warranty 2015-4037 In Stock £62.26
GF08 APC Service Pack 3 Year Warranty Extension In Stock £107.26
GF08 APC Service Pack 3 Year Warranty Extension In Stock £116.60
GF08 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.92
GF08 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £689.02
GF08 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,271.81
GF08 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £164.37
GF08 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,309.18
GF08 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £83.54
GF08 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £467.09
Brand: APC
Price Range Ex VAT: £1000 - £1500
