LCD graphics display
Text and mimic diagrams that display modes of operation, system parameters and alarms. -
ECO Mode
Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection. -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
- APC Smart-UPS SRT 1000VA RM - UPS - 1000 Watt - 1000 VA
- UPS - Power Factor Correction (PFC) - rack-mountable
- Rack Size
- 2U
- 21 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 220/230/240 V ± 2%
- Power Capacity
- 1000 Watt / 1000 VA
- Input Connectors
- 1 x power IEC 60320 C14, power BS 1363A, Europlug (power CEE 7/16)
- Output connectors
- 6 x power IEC 60320 C13
- Battery
- Lead Acid
- Run Time (Up To)
- 8.5 min at full load
- Networking
- RS-232, USB
- Black
- 43.2 cm x 50.5 cm x 8.5 cm
- Environmental Standards
- ENERGY STAR
- 3-year warranty
- Height (Rack Units)
- 2U
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 50 - 150 / 80 - 150 V
- Frequency Provided
- 50/60 Hz ± 3Hz
- Frequency Required
- 40 - 70 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V ± 2% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 432 Joules
- Circuit Protection
- Circuit breaker
- Technology
- Lead Acid
- Run Time (Up To)
- 8.5 min at full load , 21.1 min at half load , 9.8 min at 900 Watts , 13.8 min at 700 Watts , 59.6 min at 200 Watts
- Recharge Time
- 3 hours
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) - RJ-45 , 1 x EPO (emergency power off) , 1 x management (USB)
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- Power cable 1.83 m , USB cable - external
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, internal bypass, LED indicators, cold-start function, firmware upgradable, automatic self-test, hot-swappable batteries, Eco-Mode, reset breaker
- RoHS, REACH, IP20, EAC
- Software Included
- APC PowerChute Business Edition
Sustainability Information
- ENERGY STAR
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Sound Emission
- 50 dBA
- 43.2 cm
- 50.5 cm
- 8.5 cm
- 21 kg
- Shipping Width
- 59.4 cm
- Shipping Depth
- 74.9 cm
- Shipping Height
- 24.6 cm
- Shipping Weight
- 29.6 kg
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £201.83 |
APC 1U Vertical Cable Organiser | In Stock | £122.63 |
APC 1U Horizontal Cable Organiser | In Stock | £54.81 |
APC - rack cable guide - 1U | In Stock | £50.93 |
APC Rackmount Rail Kit | In Stock | £90.64 |
APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT | In Stock | £205.21 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £294.96 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £324.11 |
APC Temperature and Humidity Sensor | In Stock | £133.00 |
APC Equipment Support Rails for 600mm Wide Enclosure | In Stock | £73.13 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £287.01 |
APC Cable Managers (Qty 10) | In Stock | £35.06 |
APC 2G Power distribution strip | In Stock | £644.42 |
APC Rack PDU 2G METERED ZEROU | In Stock | £684.31 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £977.00 |
APC 19" Rack LCD Console | In Stock | £1,381.85 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £80.98 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £66.10 |
APC 1U Blanking Panel Kit | In Stock | £34.68 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £55.98 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.26 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £69.10 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £635.18 |
APC Metered Rack PDU | In Stock | £844.24 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £744.71 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £263.99 |
APC Smart-UPS SRT 19 INCH Rail Kit for SRT 2.2/3kVA | In Stock | £177.26 |
APC Service Pack 1 Year Warranty Extension | In Stock | £44.34 |
APC 1 Year Extended Warranty 2015-4037 | In Stock | £62.16 |
APC Service Pack 3 Year Warranty Extension | In Stock | £104.39 |
APC Service Pack 3 Year Warranty Extension | In Stock | £113.71 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £61.13 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,140.15 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £669.91 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,254.76 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £159.28 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £82.86 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £469.02 |
