Text and mimic diagrams display modes of operation, system parameters and alarms. Operating mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
LCD graphics display
Text and mimic diagrams that display modes of operation, system parameters and alarms. -
10/100 BaseT connection
Connect the device to a network using a 10 or 100 BaseT connection -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance
- APC Smart-UPS SRT 10000VA RM - UPS - 10 kW - 10000 VA
- UPS - rack-mountable
- Rack Size
- 6U
- 111.82 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 3%
- Power Capacity
- 10 kW / 10000 VA
- Input Connectors
- Hardwire 5-wire (3PH + N + G), hardwire 3-wire (1PH + N + G)
- Output connectors
- 6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 1 x hardwire 3-wire (HN + G) , 3 x IEC connector
- Battery
- Lead Acid
- Run Time (Up To)
- 3.8 min at full load
- Networking
- Ethernet 10/100, USB
- Black
- 43.2 cm x 71.5 cm x 26.3 cm
- 3-year warranty
- Designed For
- P/N: ACDC2513, AR2401, AR2487G, AR2507, AR2580, AR2587, AR3100G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300G, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, NBWL0356A
- Height (Rack Units)
- 6U
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 230 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 45 - 65 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 3% - 50/60 Hz
- Power Capacity
- 10 kW / 10000 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 480 Joules
- Efficiency
- 98%
- Technology
- Lead Acid
- Run Time (Up To)
- 3.8 min at full load , 11.5 min at half load
- Recharge Time
- 3 hours
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- 1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Audible alarm, LCD display
- C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Sound Emission
- 55 dBA
- 43.2 cm
- 71.5 cm
- 26.3 cm
- 111.82 kg
- Shipping Width
- 60 cm
- Shipping Depth
- 1 m
- Shipping Height
- 46.1 cm
- Shipping Weight
- 130 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC2513, ACF001, ACF002, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £28.30 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £49.51 |
APC - Power cable - Male-Female - 1.98 m | In Stock | £49.24 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £200.57 |
APC 1U Vertical Cable Organiser | In Stock | £121.84 |
APC 1U Horizontal Cable Organiser | In Stock | £52.53 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £52.60 |
APC - rack cable guide - 1U | In Stock | £50.87 |
APC Power cable - 2.4 m | In Stock | £83.54 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £294.54 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £312.30 |
APC Temperature and Humidity Sensor | In Stock | £134.30 |
APC POWER CORD C13 TO C20 1.98m Black | In Stock | £51.68 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £286.43 |
APC Cable Managers (Qty 10) | In Stock | £34.73 |
APC 2G Power distribution strip | In Stock | £641.57 |
APC Rack PDU 2G METERED ZEROU | In Stock | £696.98 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £967.85 |
APC 19" Rack LCD Console | In Stock | £1,379.88 |
APC Power Cord Locking C19 to IEC309-16A 3.0m | In Stock | £84.10 |
APC Power Cord Locking C19 to C20 3.0m | In Stock | £69.38 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £81.14 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £52.24 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £65.94 |
APC 1U Blanking Panel Kit | In Stock | £34.12 |
APC Smart-UPS SRT 192V 5kVA and 6kVA Battery Pack | In Stock | £1,237.89 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £55.89 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £47.93 |
APC Power Cable (pack of 6) 1.22m | In Stock | £85.96 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,596.51 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £68.85 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £130.73 |
APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh | In Stock | £580.98 |
APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £99.24 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £633.29 |
APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA | In Stock | £225.33 |
APC Smart-UPS SRT 72V 2.2kVA RM Battery Pack Battery Enclosure | In Stock | £935.63 |
APC Smart-UPS SRT 96V 3kVA RM Battery Pack - Lead Acid | In Stock | £1,193.70 |
APC Smart-UPS SRT 192V 8 and 10kVA RM Battery Pack | In Stock | £1,616.89 |
APC Metered Rack PDU | In Stock | £827.64 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £730.84 |
APC Smart-UPS SRT 72V 2.2kVA Battery Pack | In Stock | £764.71 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,081.07 |
APC Smart-UPS SRT 96V 3kVA Battery Pack | In Stock | £1,201.69 |
APC Service Pack 3 Year Warranty Extension | In Stock | £1,003.66 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £61.06 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,136.42 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £668.89 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,252.97 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £161.08 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £82.74 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £468.44 |
