APC Smart-UPS SRT 10000VA RM 230V
Quicklinx: D9S6WS00 Mfr#: SRT10KRMXLI
Type: Power
£7,572.57 ex VAT
£9,087.08 inc VAT
Text and mimic diagrams display modes of operation, system parameters and alarms. Operating mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • 10/100 BaseT connection
    Connect the device to a network using a 10 or 100 BaseT connection
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
APC Smart-UPS SRT 10000VA RM - UPS - 10 kW - 10000 VA
UPS - rack-mountable
Rack Size
6U
111.82 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
10 kW / 10000 VA
Input Connectors
Hardwire 5-wire (3PH + N + G), hardwire 3-wire (1PH + N + G)
Output connectors
6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 1 x hardwire 3-wire (HN + G) , 3 x IEC connector
Lead Acid
Run Time (Up To)
3.8 min at full load
Ethernet 10/100, USB
43.2 cm x 71.5 cm x 26.3 cm
3-year warranty
P/N: ACDC2513, AR2401, AR2487G, AR2507, AR2580, AR2587, AR3100G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300G, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, NBWL0356A
Height (Rack Units)
6U
UPS Technology
On-line
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
10 kW / 10000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Efficiency
98%
Lead Acid
Run Time (Up To)
3.8 min at full load , 11.5 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Audible alarm, LCD display
C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
43.2 cm
71.5 cm
26.3 cm
111.82 kg
Shipping Width
60 cm
Shipping Depth
1 m
Shipping Height
46.1 cm
Shipping Weight
130 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC2513, ACF001, ACF002, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
D9S6 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.44
D9S6 APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £48.99
D9S6 APC - Power cable - Male-Female - 1.98 m In Stock £50.90
D9S6 APC Basic Rack-Mount PDU - power distribution strip In Stock £202.03
D9S6 APC 1U Vertical Cable Organiser In Stock £122.75
D9S6 APC 1U Horizontal Cable Organiser In Stock £54.86
D9S6 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.74
D9S6 APC Netshelter heavy duty shelf In Stock £142.89
D9S6 APC - rack cable guide - 1U In Stock £51.09
D9S6 APC Power cable - 2.4 m In Stock £84.15
D9S6 APC Rack PDU Basic Zero U 16A 208/230V In Stock £299.80
D9S6 APC Rack PDU Basic Zero U 32A 230V In Stock £320.46
D9S6 APC Temperature and Humidity Sensor In Stock £133.14
D9S6 APC POWER CORD C13 TO C20 1.98m Black In Stock £52.05
D9S6 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £287.81
D9S6 APC Cable Managers (Qty 10) In Stock £35.34
D9S6 APC 2G Power distribution strip In Stock £645.98
D9S6 APC Rack PDU 2G METERED ZEROU In Stock £689.69
D9S6 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £984.76
D9S6 APC 19" Rack LCD Console In Stock £1,385.59
D9S6 APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £84.15
D9S6 APC Power Cord Locking C19 to C20 3.0m In Stock £68.64
D9S6 APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.00
D9S6 APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £53.14
D9S6 APC NetShelter Zero U Accessory Mounting Bracket In Stock £66.29
D9S6 APC 1U Blanking Panel Kit In Stock £34.72
D9S6 APC Smart-UPS SRT 192V 5kVA and 6kVA Battery Pack In Stock £1,346.49
D9S6 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.96
D9S6 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.30
D9S6 APC Power Cable (pack of 6) 1.22m In Stock £87.46
D9S6 APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,694.93
D9S6 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.94
D9S6 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £131.85
D9S6 APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh In Stock £585.19
D9S6 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £101.73
D9S6 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £636.90
D9S6 APC Smart-UPS SRT 72V 2.2kVA RM Battery Pack Battery Enclosure In Stock £949.02
D9S6 APC Metered Rack PDU In Stock £846.52
D9S6 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £736.14
D9S6 APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £264.70
D9S6 APC Smart-UPS SRT 96V 3kVA Battery Pack In Stock £1,210.54
D9S6 APC Service Pack 3 Year Warranty Extension In Stock £1,010.60
D9S6 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.44
D9S6 APC Switched PDU 10A 0U C13x16 In Stock £1,164.00
D9S6 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £671.74
D9S6 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,258.20
D9S6 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £162.29
D9S6 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,287.30
D9S6 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £81.93
D9S6 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £470.30
Type: Power
Brand: APC
Price Range Ex VAT: £1500+
