APC Smart-UPS SC is the perfect protection for the IT resources of your growing business. Manageable and cost effective, APC Smart-UPS SC is designed for use by small and medium companies looking to protect networking equipment, providing both power and data-line protection. Included PowerChute Business Edition management software allows you to configure safe system shutdowns and take advantage of advanced UPS management features like automated risk assessments and runtime capacity calculations. Communications are through your server's standard serial port. When you are ready to take your business to the next level you can use the same software environment found on Smart-UPS SC to seamlessly manage other Smart-UPS models, allowing you to grow your IT infrastructure without having to replace your software or retrain your administrators. Built on the same standards as the award winning Smart-UPS UPS, the Smart-UPS SC is the UPS to start your business with.
Battery-protected and surge-only outlets
Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
- APC Smart-UPS SC 620VA - UPS - 390 Watt - 620 VA
- UPS - external
- 12 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 390 Watt / 620 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 3 x power IEC 60320 C13 (UPS and surge) , 1 x power IEC 60320 C13 (surge)
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Run Time (Up To)
- 5.5 min at full load
- Networking
- RS-232
- Grey
- 11.9 cm x 36.8 cm x 16.8 cm
- 2-year warranty
- UPS - external
- Battery Enclosure Type
- Internal
- Grey
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 286 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 5% - 50/60 Hz
- Power Capacity
- 390 Watt / 620 VA
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 320 Joules
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- Remote Management Interface
- RS-232
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Cables Included
- Serial cable
- Audible alarm, audible alarm, LED indicators
- FCC Class B certified, CSA, NOM, UL 1449, UL 1778, FCC Part 15
- Software Included
- APC PowerChute Business Edition
- Limited warranty - parts and labour - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 45 dBA
- 11.9 cm
- 36.8 cm
- 16.8 cm
- 12 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £28.30 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £49.51 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £52.60 |
APC Power Cable (pack of 6) 1.22m | In Stock | £85.96 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £130.73 |
APC Service Pack 1 Year Warranty Extension | In Stock | £44.31 |
APC Service Pack 3 Year Warranty Extension | In Stock | £105.53 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £61.06 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,136.42 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £468.44 |
APC BackUPS 600/650 Battery | In Stock | £94.99 |
