APC Smart-UPS SC 620VA
Quicklinx: 3VM0WS00 Mfr#: SC620I
Type: UPS
Power Rating: 390Watt
£287.45 ex VAT
£344.94 inc VAT
APC Smart-UPS SC is the perfect protection for the IT resources of your growing business. Manageable and cost effective, APC Smart-UPS SC is designed for use by small and medium companies looking to protect networking equipment, providing both power and data-line protection. Included PowerChute Business Edition management software allows you to configure safe system shutdowns and take advantage of advanced UPS management features like automated risk assessments and runtime capacity calculations. Communications are through your server's standard serial port. When you are ready to take your business to the next level you can use the same software environment found on Smart-UPS SC to seamlessly manage other Smart-UPS models, allowing you to grow your IT infrastructure without having to replace your software or retrain your administrators. Built on the same standards as the award winning Smart-UPS UPS, the Smart-UPS SC is the UPS to start your business with.
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
APC Smart-UPS SC 620VA - UPS - 390 Watt - 620 VA
UPS - external
12 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
390 Watt / 620 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
3 x power IEC 60320 C13 (UPS and surge) , 1 x power IEC 60320 C13 (surge)
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
5.5 min at full load
RS-232
Grey
11.9 cm x 36.8 cm x 16.8 cm
UPS - external
Battery Enclosure Type
Internal
Grey
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
390 Watt / 620 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
320 Joules
Quantity
1
Lead Acid
Run Time (Up To)
Remote Management Interface
RS-232
1 x RS-232 - 9 pin D-Sub (DB-9)
Serial cable
Audible alarm, audible alarm, LED indicators
FCC Class B certified, CSA, NOM, UL 1449, UL 1778, FCC Part 15
Software Included
APC PowerChute Business Edition
Limited warranty - parts and labour - 2 years
0 - 95%
Sound Emission
45 dBA
11.9 cm
36.8 cm
16.8 cm
12 kg
3VM0 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £29.14
3VM0 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £51.21
3VM0 APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £56.66
3VM0 APC Power Cable (pack of 6) 1.22m In Stock £85.01
3VM0 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £126.78
3VM0 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £101.53
3VM0 APC Service Pack 1 Year Warranty Extension In Stock £42.61
3VM0 APC Service Pack 3 Year Warranty Extension In Stock £95.60
3VM0 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £59.86
3VM0 APC Switched PDU 10A 0U C13x16 In Stock £1,139.17
3VM0 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £651.34
3VM0 APC BackUPS 600/650 Battery In Stock £93.34
Resources
The following resources are available for the APC Smart-UPS SC 620VA
Type: UPS
Brand: APC
