APC Smart-UPS SC 420VA 260W
Quicklinx: 3M9FWS00 Mfr#: SC420I
Type: UPS
Power Rating: 260watt
£239.73 ex VAT
£287.67 inc VAT
APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATM's.
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
APC Smart-UPS SC 420VA - UPS - 260 Watt - 420 VA
UPS - external
9 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
260 Watt / 420 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Plug-in module
Run Time (Up To)
5.5 min at full load
Grey
12 cm x 37 cm x 17 cm
UPS - external
Battery Enclosure Type
Plug-in module
Grey
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V
Power Capacity
260 Watt / 420 VA
Dataline Surge Protection
Ethernet 10/100Base-TX - RJ-45
Surge Suppression
Surge Energy Rating
320 Joules
Lead Acid
Run Time (Up To)
1 x RS-232 - 9 pin D-Sub (DB-9)
Power cable - integrated - 1.8 m , Serial cable
Audible alarm
FCC Class B certified, CSA, NOM, UL 1449, UL 1778, FCC Part 15
Software Included
APC PowerChute Business Edition
Limited warranty - parts and labour - 2 years
0 - 95%
12 cm
37 cm
17 cm
9 kg
3M9F APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.04
3M9F APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £54.43
3M9F APC BackUPS 250/280/400 Replacement Battery Cartridge In Stock £61.93
3M9F APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £58.86
3M9F APC Power Cable (pack of 6) 1.22m In Stock £90.09
3M9F APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £132.63
3M9F APC Service Pack 1 Year Warranty Extension In Stock £49.20
3M9F APC Service Pack 3 Year Warranty Extension In Stock £107.81
3M9F APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.58
3M9F APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £682.35
3M9F APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £466.12
Resources
The following resources are available for the APC Smart-UPS SC 420VA 260W
Type: UPS
Brand: APC
