APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATM's.
Battery-protected and surge-only outlets
Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
- APC Smart-UPS SC 420VA - UPS - 260 Watt - 420 VA
- UPS - external
- 9 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 260 Watt / 420 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 4 x power IEC 60320 C13
- Battery
- Lead Acid
- Battery Form Factor
- Plug-in module
- Run Time (Up To)
- 5.5 min at full load
- Grey
- 12 cm x 37 cm x 17 cm
- 2-year warranty
- UPS - external
- Battery Enclosure Type
- Plug-in module
- Grey
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 286 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V
- Power Capacity
- 260 Watt / 420 VA
- Dataline Surge Protection
- Ethernet 10/100Base-TX - RJ-45
- Surge Suppression
- Surge Energy Rating
- 320 Joules
- Technology
- Lead Acid
- Run Time (Up To)
- 1 x RS-232 - 9 pin D-Sub (DB-9)
- Cables Included
- Power cable - integrated - 1.8 m , Serial cable
- Audible alarm
- FCC Class B certified, CSA, NOM, UL 1449, UL 1778, FCC Part 15
- Software Included
- APC PowerChute Business Edition
- Limited warranty - parts and labour - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 12 cm
- 37 cm
- 17 cm
- 9 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £30.86 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £50.84 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £53.51 |
APC BackUPS 250/280/400 Replacement Battery Cartridge | In Stock | £59.60 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £59.03 |
APC Power Cable (pack of 6) 1.22m | In Stock | £88.51 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £130.53 |
APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £105.93 |
APC Service Pack 1 Year Warranty Extension | In Stock | £49.36 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £61.68 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £702.09 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £467.04 |
