APC Smart-UPS SC 1500VA - UPS - 865 Watt - 1500 VA
Customer rating: 1.0* (Write a review)
Quicklinx: 47VPWS00 Mfr#: SC1500I
APC Smart-UPS SC is the perfect protection for the IT resources of your growing business. Manageable and cost effective, APC Smart-UPS SC is designed for use by small and medium companies looking to protect networking equipment, providing both power and data-line protection. Included PowerChute Business Edition management software allows you to configure safe system shutdowns and take advantage of advanced UPS management features like automated risk assessments and runtime capacity calculations. (All major operating systems supported). Communications are through your server's standard serial port. When you are ready to take your business to the next level you can use the same software environment found on Smart-UPS SC to seamlessly manage other Smart-UPS models, allowing you to grow your IT infrastructure without having to replace your software or retrain your administrators. Built on the same standards as the award winning Smart-UPS UPS, the Smart-UPS SC is the UPS to start your business with.
UPS - external
Rack Size
2U
21.4 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
865 Watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Internal
Run Time (Up To)
7.6 min at full load
Grey
43.2 cm x 46.3 cm x 8.9 cm
UPS - external
Battery Enclosure Type
Internal
Height (Rack Units)
2U
Grey
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 175 - 295 V
Input Voltage Range (Adjustable)
AC 160 - 286 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
865 Watt / 1500 VA
Dataline Surge Protection
Network - RJ-45
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Response Time
0 ns
Surge Energy Rating
445 Joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
Recharge Time
8 hours
1 x management (RS-232) - 9 pin D-Sub (DB-9)
Serial cable - external , Power cable 1.8 m
Rack Mounting Kit
Included
Audible alarm, Automatic Voltage Regulation (AVR), LED indicators
C-Tick, GOST, UL 1449, VDE
Software Included
Drivers & Utilities
0 - 95%
Sound Emission
45 dBA
43.2 cm
46.3 cm
8.9 cm
21.4 kg
47VP APC Replacement Battery Cartridge #59 In Stock £151.70
Resources
The following resources are available for the APC Smart-UPS SC 1500VA - UPS - 865 Watt - 1500 VA
Customer reviews
Write a review for the APC Smart-UPS SC 1500VA - UPS - 865 Watt - 1500 VA here!
Not suitable for normal servers
Reviewed by Pete Smith. Review Posted 22/12/2008
I recently had one of these units fail within 1 week. It was connected to a server which was not particularly power hungry. APC refused to have anything to do with it because they say the unit is not suitable for servers that use more than 150W. This information is not evident in any of the documentation, so beware.
  • Overall 1*
  • Ease of use 5*
  • Value for money 2*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
