APC Smart-UPS RT is a family of high-density, performance UPSs for voice and data networks, medical labs, and light industrial applications. This flexible form factor allows standardization across multiple applications. High power internal chargers allow virtually unlimited additional matching battery packs to comply with aggressive runtime demands of business-critical systems. Customers with harsh power environments looking for extremely tight voltage and frequency regulation, internal bypass, and input power factor correction typical of double conversion online topology will get them in the Smart-UPS RT.
User-replaceable batteries
Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR) -
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced -
Plug-and-Play external batteries
Ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS
- APC Smart-UPS RT 192V RM Battery Pack - battery enclosure - Lead Acid
- Battery enclosure - rack-mountable
- Rack Size
- 19" - 6U
- 182 kg
- Output Voltage
- 192 V
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 4
- Black
- 43.2 cm x 73.9 cm x 26.3 cm
- 2-year warranty
- Designed For
- P/N: AR3103, AR3103SP, AR3106SP, AR3357X674, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, SURT14KRMXLJ, SURT15KRMXLI, SURT15KRMXLT, SURT15KRMXLT-1TF10K, SURT15KRMXLT-TF5, SURT15KUXICH, SURT18KRMXLJ, SURT20KRMXLI, SURT20KRMXLT, SURT20KRMXLT-1TF10K, SURT20KRMXLT-TF5, SURT20KUXICH, SURT20KUXI-IN
- Battery Enclosure Type
- Internal
- Height (Rack Units)
- 6U
- Rack Size
- 19"
- Black
- Output Voltage
- 192 V
- Quantity
- 4
- Technology
- Lead Acid
- Rack Mounting Kit
- Included
- Hot-swappable
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 43.2 cm
- 73.9 cm
- 26.3 cm
- 182 kg
- Shipping Width
- 61 cm
- Shipping Depth
- 100 cm
- Shipping Height
- 43.2 cm
- Shipping Weight
- 220 kg
- Designed For
APC Service Pack 3 Year Warranty Extension (for new purchases) | In Stock | £552.94 |
APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh | In Stock | £582.97 |
APC Extended Warranty Renewal Technical Support (Renewal) 3 Years | In Stock | £769.54 |
APC Service Pack 1 Year Warranty Extension | In Stock | £239.49 |
