APC Smart-UPS RT 8000VA RM 230V
Quicklinx: 4CZTWS00 Mfr#: SURT8000RMXLI
APC Smart-UPS RT is a family of high-density, performance UPSs for voice and data networks, medical labs, and light industrial applications. 6U form factor allows standardization across multiple applications. High power internal chargers allow virtually unlimited additional matching battery packs to comply with aggressive runtime demands of business-critical systems. Customers with harsh power environments looking for extremely tight voltage and frequency regulation, internal bypass, and input power factor correction typical of double conversion online topology will get them in the Smart-UPS RT.
APC Smart-UPS RT 8000VA RM - UPS - 8000 VA
UPS - rack-mountable
Rack Size
6U
111 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 3%
Power Capacity
8000 VA
Input Connectors
2 x hardwire 5-wire (3PH + N + G), hardwire 3-wire (1PH + N + G)
Output connectors
1 x hardwire 3-wire (HN + G) , 4 x power IEC 60320 C13 , 4 x power IEC 60320 C19
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
2
Run Time (Up To)
6.3 min at full load
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, HTTP
43.2 cm x 66.3 cm x 26.3 cm
P/N: AR2200, AR2280, AR2487G, AR3100TAA, AR3100W, AR3103SP, AR3105SP, AR3105W, AR3106SP, AR3107SP, AR3140G, AR3140W, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3340G, AR3340W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, NBWL0356A
Battery Enclosure Type
Plug-in module
Height (Rack Units)
6U
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 3% - 50/60 Hz
Power Capacity
8000 VA
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Quantity
2
Lead Acid
Run Time (Up To)
Recharge Time
2.2 hours
Remote Management Interface
SNMP, HTTP
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (Ethernet) - RJ-45
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Serial cable - external
Rack Mounting Kit
Included
Audible alarm, emergency power off, internal bypass, LED indicators
C-Tick, GOST, EN 60950, EN 61000-3-2, UL 1449, VDE, EN55022 Class A, EN 50091-2, EN 50091-1
0 - 95%
Sound Emission
55 dBA
43.2 cm
66.3 cm
26.3 cm
111 kg
Shipping Width
59.7 cm
Shipping Depth
99.1 cm
Shipping Height
55.2 cm
Shipping Weight
129 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103SP, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR3814, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
Resources
The following resources are available for the APC Smart-UPS RT 8000VA RM 230V
