APC SMART-UPS RT 6000VA 230V
Quicklinx: F7FRWS00 Mfr#: SURT6000XLIM
Power Rating: 4.2kW
£3,614.78 ex VAT
£4,337.73 inc VAT
Smart-UPS On-Line provides high density, true double-conversion on-line power protection for servers, voice/data networks, medical labs, and light industrial applications. Recent family extensions at 15 and 20 kVA enable support of power hungry blade servers or heavily loaded equipment racks. When business-critical systems require runtime in hours, not minutes, Smart-UPS On-Line can be configured with matching battery packs to comply with aggressive runtime demands. The entire Smart-UPS On-Line family provides value to customers with demanding power environments, including very wide input voltage window, extremely tight output voltage regulation, frequency regulation, internal bypass, and input power factor correction.
  • Automatic internal bypass
    Supplies utility power to the connected loads in the event of a UPS overload condition or fault.
  • Scalable runtime
    It allows additional run time to be quickly added as needed.
  • Intelligent battery management
    It maximizes battery performance, life, and reliability through intelligent, precision charging.
  • Hot-swappable batteries
    It ensures clean, uninterrupted power to protected equipment while batteries are being replaced.
  • Automatic restart of loads after UPS shutdown
    Automatically starts up the connected equipment upon the return of utility power.
  • Temperature-compensated battery charging
    It prolongs battery life by regulating the charge voltage according to battery temperature.
  • Network manageable
    It provides remote management of the UPS over the network.
  • InfraStruXure manager compatible
    Enables centralized management via the APC InfraStruXure manager.
  • SmartSlot
    Customize UPS capabilities with management cards.
  • LED status indicators
    Quickly understand unit and power status with visual indicators.
  • Serial connectivity
    It provides management of the UPS via a serial port.
  • Plug-and-Play external batteries
    It ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS.
  • Rack/Tower convertible
    It protects the initial investment in the UPS when migrating from tower to rack-mount environment.
  • Flash upgradeable firmware
    Install maintenance releases of firmware remotely using FTP.
  • User-replaceable batteries
    It increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR).
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced.
  • Predicitive failure notification
    It provides early-warning fault analysis ensuring proactive component replacement.
  • Disconnected battery notification
    It warns when a battery is not available to provide backup power.
  • Audible alarms
    Provides notification of changing utility power and UPS conditions.
  • Frequency and voltage regulation
    It gives higher application availability by correcting poor frequency and voltage conditions without using the battery.
  • Power conditioning
    Protects connected loads from surges, spikes, lightning, and other power disturbances.
  • Input power factor correction
    It minimizes installation costs by enabling the use of smaller generators and cabling.
  • Generator compatible
    It ensures clean, uninterrupted power to protected equipment when generator power is used.
  • Cold-start capable
    It provides temporary battery power when the utility power is out.
  • Resettable circuit breaker
    It is easy recovery from overloads; no need to replace a fuse.
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment.
APC Smart-UPS RT 6000 Marine - UPS - 4.2 kW - 6000 VA
UPS - external
Rack Size
3U
54.5 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 1%
Power Capacity
4.2 kW / 6000 VA
Input Connectors
Hardwire 3-wire (HN + G)
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid
Battery Form Factor
Plug-in module
Run Time (Up To)
5 min at full load
RS-232
13 cm x 66 cm x 43.2 cm
UPS - external
Battery Enclosure Type
Plug-in module
Height (Rack Units)
3U
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 280 V
Input Voltage Range (Adjustable)
AC 100 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 1% - 50/60 Hz
Power Capacity
4.2 kW / 6000 VA
Output Waveform
Sinewave
Surge Suppression
Lead Acid
Run Time (Up To)
5 min at full load
Remote Management Interface
RS-232
1 x management (RS-232) - RJ-45 , 1 x EPO (emergency power off)
Expansion Slots
1 SmartSlot
Rack Mounting Kit
Included
Audible alarm, emergency power off, internal bypass, LED indicators
Software Included
Drivers & Utilities
55 °C
13 cm
66 cm
43.2 cm
54.5 kg
F7FR APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £205.01
F7FR APC Service Pack 3 Year Warranty Extension (for new purchases) In Stock £511.94
F7FR APC Dry Contact I/O SmartSlot Card In Stock £169.64
F7FR APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh In Stock £569.93
F7FR APC Extended Warranty Renewal Technical Support (Renewal) 3 Years In Stock £729.07
F7FR APC Service Pack 1 Year Warranty Extension In Stock £226.83
Power Rating: 4.2kW
Brand: APC
Price Range Ex VAT: £1500+
