Smart-UPS On-Line provides high density, true double-conversion on-line power protection for servers, voice/data networks, medical labs, and light industrial applications. Recent family extensions at 15 and 20 kVA enable support of power hungry blade servers or heavily loaded equipment racks. When business-critical systems require runtime in hours, not minutes, Smart-UPS On-Line can be configured with matching battery packs to comply with aggressive runtime demands. The entire Smart-UPS On-Line family provides value to customers with demanding power environments, including very wide input voltage window, extremely tight output voltage regulation, frequency regulation, internal bypass, and input power factor correction.
Automatic internal bypass
Supplies utility power to the connected loads in the event of a UPS overload condition or fault. -
Scalable runtime
It allows additional run time to be quickly added as needed. -
Intelligent battery management
It maximizes battery performance, life, and reliability through intelligent, precision charging. -
Hot-swappable batteries
It ensures clean, uninterrupted power to protected equipment while batteries are being replaced. -
Automatic restart of loads after UPS shutdown
Automatically starts up the connected equipment upon the return of utility power. -
Temperature-compensated battery charging
It prolongs battery life by regulating the charge voltage according to battery temperature. -
Network manageable
It provides remote management of the UPS over the network. -
InfraStruXure manager compatible
Enables centralized management via the APC InfraStruXure manager. -
SmartSlot
Customize UPS capabilities with management cards. -
LED status indicators
Quickly understand unit and power status with visual indicators. -
Serial connectivity
It provides management of the UPS via a serial port. -
Plug-and-Play external batteries
It ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS. -
Rack/Tower convertible
It protects the initial investment in the UPS when migrating from tower to rack-mount environment. -
Flash upgradeable firmware
Install maintenance releases of firmware remotely using FTP. -
User-replaceable batteries
It increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR). -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced. -
Predicitive failure notification
It provides early-warning fault analysis ensuring proactive component replacement. -
Disconnected battery notification
It warns when a battery is not available to provide backup power. -
Audible alarms
Provides notification of changing utility power and UPS conditions. -
Frequency and voltage regulation
It gives higher application availability by correcting poor frequency and voltage conditions without using the battery. -
Power conditioning
Protects connected loads from surges, spikes, lightning, and other power disturbances. -
Input power factor correction
It minimizes installation costs by enabling the use of smaller generators and cabling. -
Generator compatible
It ensures clean, uninterrupted power to protected equipment when generator power is used. -
Cold-start capable
It provides temporary battery power when the utility power is out. -
Resettable circuit breaker
It is easy recovery from overloads; no need to replace a fuse. -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment.
- APC Smart-UPS RT 6000 Marine - UPS - 4.2 kW - 6000 VA
- UPS - external
- Rack Size
- 3U
- 54.5 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 220/230/240 V ± 1%
- Power Capacity
- 4.2 kW / 6000 VA
- Input Connectors
- Hardwire 3-wire (HN + G)
- Output connectors
- 8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
- Battery
- Lead Acid
- Battery Form Factor
- Plug-in module
- Run Time (Up To)
- 5 min at full load
- Networking
- RS-232
- 13 cm x 66 cm x 43.2 cm
- UPS - external
- Battery Enclosure Type
- Plug-in module
- Height (Rack Units)
- 3U
- UPS Technology
- On-line
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 160 - 280 V
- Input Voltage Range (Adjustable)
- AC 100 - 280 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 45 - 65 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V ± 1% - 50/60 Hz
- Power Capacity
- 4.2 kW / 6000 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Technology
- Lead Acid
- Run Time (Up To)
- Remote Management Interface
- RS-232
- 1 x management (RS-232) - RJ-45 , 1 x EPO (emergency power off)
- Expansion Slots
- 1 SmartSlot
- Rack Mounting Kit
- Included
- Audible alarm, emergency power off, internal bypass, LED indicators
- Software Included
- Drivers & Utilities
- 0 °C
- 55 °C
- 13 cm
- 66 cm
- 43.2 cm
- 54.5 kg
APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT | In Stock | £203.71 |
APC Service Pack 3 Year Warranty Extension (for new purchases) | In Stock | £508.30 |
APC Dry Contact I/O SmartSlot Card | In Stock | £165.13 |
APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh | In Stock | £565.88 |
APC Extended Warranty Renewal Technical Support (Renewal) 3 Years | In Stock | £723.69 |
APC Service Pack 1 Year Warranty Extension | In Stock | £225.23 |
