APC Smart-UPS RT is a family of high-density, performance UPSs for voice and data networks, medical labs, and light industrial applications. Capable of supporting 10KVA in a 6U rack/tower convertible form, users can support power hungry blade servers or heavily loaded equipment racks. This flexible form factor allows standardization across multiple applications. High power internal chargers allow virtually unlimited additional matching battery packs to comply with aggressive runtime demands of business-critical systems. Customers with harsh power environments looking for extremely tight voltage and frequency regulation, internal bypass, and input power factor correction typical of double conversion online topology will get them in the Smart-UPS RT.
- APC Smart-UPS RT - UPS - 2.1 kW - 3000 VA
- UPS - external
- Rack Size
- 3U
- 54.6 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 220/230/240 V ± 3%
- Power Capacity
- 2.1 kW / 3000 VA
- Input Connectors
- 3 x power IEC 60320 C20, power BS 1363, power CEE 7/7
- Output connectors
- 8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Run Time (Up To)
- 14.1 min at full load
- Networking
- RS-232
- Black
- 13 cm x 66 cm x 43.2 cm
- 2-year warranty
- UPS - external
- Battery Enclosure Type
- Internal
- Height (Rack Units)
- 3U
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 160 - 280 V
- Input Voltage Range (Adjustable)
- AC 100 - 280 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V ± 3% - 50/60 Hz
- Power Capacity
- 2.1 kW / 3000 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 480 joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 2.5 hours
- Remote Management Interface
- RS-232
- 1 x management (RS-232) - 25 pin D-Sub (DB-25)
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- Serial cable - external , Power cable 2.4 m
- Audible alarm, emergency power off, internal bypass, LED indicators
- CSA, VCCI, C-Tick, BSMI, GOST, EN 60950, EN 61000-3-2, JEON, UL 1778, VDE, EN55022 Class A, EN 50091-2, EN 50091-1
- Software Included
- Drivers & Utilities
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 55 dBA
- 13 cm
- 66 cm
- 43.2 cm
- 54.6 kg
- Shipping Width
- 60.3 cm
- Shipping Depth
- 98 cm
- Shipping Height
- 34.7 cm
- Shipping Weight
- 63.6 kg
