APC Smart UPS RT 3000VA 230V
Quicklinx: 58H1WS00 Mfr#: SURTD3000XLI
APC Smart-UPS RT is a family of high-density, performance UPSs for voice and data networks, medical labs, and light industrial applications. Capable of supporting 10KVA in a 6U rack/tower convertible form, users can support power hungry blade servers or heavily loaded equipment racks. This flexible form factor allows standardization across multiple applications. High power internal chargers allow virtually unlimited additional matching battery packs to comply with aggressive runtime demands of business-critical systems. Customers with harsh power environments looking for extremely tight voltage and frequency regulation, internal bypass, and input power factor correction typical of double conversion online topology will get them in the Smart-UPS RT.
APC Smart-UPS RT - UPS - 2.1 kW - 3000 VA
UPS - external
Rack Size
3U
54.6 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 3%
Power Capacity
2.1 kW / 3000 VA
Input Connectors
3 x power IEC 60320 C20, power BS 1363, power CEE 7/7
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
14.1 min at full load
RS-232
13 cm x 66 cm x 43.2 cm
UPS - external
Battery Enclosure Type
Internal
Height (Rack Units)
3U
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 280 V
Input Voltage Range (Adjustable)
AC 100 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 3% - 50/60 Hz
Power Capacity
2.1 kW / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
Recharge Time
2.5 hours
Remote Management Interface
RS-232
1 x management (RS-232) - 25 pin D-Sub (DB-25)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external , Power cable 2.4 m
Audible alarm, emergency power off, internal bypass, LED indicators
CSA, VCCI, C-Tick, BSMI, GOST, EN 60950, EN 61000-3-2, JEON, UL 1778, VDE, EN55022 Class A, EN 50091-2, EN 50091-1
Software Included
Drivers & Utilities
0 - 95%
Sound Emission
55 dBA
13 cm
66 cm
43.2 cm
54.6 kg
Shipping Width
60.3 cm
Shipping Depth
98 cm
Shipping Height
34.7 cm
Shipping Weight
63.6 kg
Resources
The following resources are available for the APC Smart UPS RT 3000VA 230V
