APC Smart-UPS RT- 6000VA/4200W
Quicklinx: 4V4CWS00 Mfr#: SURT6000XLI
APC Smart-UPS RT is a family of high-density, performance UPSs for voice and data networks, medical labs, and light industrial applications. Capable of supporting 10kVA in a 6U rack/tower convertible form, users can support power hungry blade servers or heavily loaded equipment racks. This flexible form factor allows standardization across multiple applications. High power internal chargers allow virtually unlimited additional matching battery packs to comply with aggressive runtime demands of business-critical systems. Customers with harsh power environments looking for extremely tight voltage and frequency regulation, internal bypass, and input power factor correction typical of double conversion online topology will get them in the Smart-UPS RT.
APC Smart-UPS RT - UPS - 6000 VA
UPS - external
Rack Size
3U
54.6 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 3%
Power Capacity
6000 VA
Input Connectors
1 x hardwire
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
1
Run Time (Up To)
3.3 min at full load
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
13 cm x 66 cm x 43.2 cm
P/N: AR3003, AR3003SP, AR3006, AR3006SP, AR3103, AR3103SP, AR3106, AR3106SP, AR3357X674
UPS - external
Battery Enclosure Type
Plug-in module
Height (Rack Units)
3U
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 280 V
Input Voltage Range (Adjustable)
AC 100 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x hardwire
Output Voltage
AC 220/230/240 V ± 3% - 50/60 Hz
Power Capacity
6000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
Recharge Time
2.5 hours
Remote Management Interface
SNMP, Telnet, HTTP
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (Ethernet) - RJ-45
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Power cable 3.1 m , Serial cable - external
Audible alarm, emergency power off, internal bypass, LED indicators
C-Tick, GOST, EN 60950, EN 61000-3-2, UL 1449, VDE, EN55022 Class A, EN 50091-2, EN 50091-1
Software Included
Drivers & Utilities
0 - 95%
Sound Emission
55 dBA
13 cm
66 cm
43.2 cm
54.6 kg
Shipping Width
60.3 cm
Shipping Depth
98 cm
Shipping Height
34.7 cm
Shipping Weight
63.6 kg
Resources
The following resources are available for the APC Smart-UPS RT- 6000VA/4200W
