APC Smart-UPS RT- 2000VA/1400W
Quicklinx: 4V4BWS00 Mfr#: SURT2000XLI
Smart-UPS RT is a family of high performance UPSs for servers, networking equipment, telecommunication systems, industrial and medical equipment, and other mission-critical applications. Smart-UPS RT UPSs are based on the field-proven, industry-leading Smart-UPS functionality, but feature double conversion on-line topology, which delivers tight voltage and frequency regulation, zero transfer time to and from battery, and input power factor correction. While offering advanced performance and high availability features, the Smart-UPS RT can be managed using PowerChute software, as well as an array of SmartSlot accessories. Smart-UPS RT provides battery back up to the load through the use of internal batteries. However, an unlimited number of external battery packs can be added to meet desired levels of runtime. All Smart-UPS RTs and battery packs ship in tower configuration, while easily converting to the 19" rack-mount mode with the addition of an APC Rail Kit.
  • Automatic internal bypass
    Supplies utility power to the connected loads in the event of a UPS overload condition or fault.
  • Scalable runtime
    It allows additional run time to be quickly added as needed.
  • Intelligent battery management
    It maximizes battery performance, life, and reliability through intelligent, precision charging.
  • Hot-swappable batteries
    It ensures clean, uninterrupted power to protected equipment while batteries are being replaced.
  • Automatic restart of loads after UPS shutdown
    Automatically starts up the connected equipment upon the return of utility power.
  • Temperature-compensated battery charging
    It prolongs battery life by regulating the charge voltage according to battery temperature.
  • Plug-and-Play external batteries
    It ensures clean, uninterrupted power to the loads when adding extra runtime to the UPS.
  • Rack/Tower convertible
    It protects the initial investment in the UPS when migrating from tower to rack-mount environment.
  • Flash upgradeable firmware
    Install maintenance releases of firmware remotely using FTP.
  • User-replaceable batteries
    It increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR).
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced.
  • Predictive failure notification
    It provides early-warning fault analysis ensuring proactive component replacement.
  • Disconnected battery notification
    It warns when a battery is not available to provide backup power.
  • Audible alarms
    Provides notification of changing utility power and UPS conditions.
  • Frequency and voltage regulation
    It gives higher application availability by correcting poor frequency and voltage conditions without using the battery.
  • Power conditioning
    Protects connected loads from surges, spikes, lightning, and other power disturbances.
  • Input power factor correction
    It minimizes installation costs by enabling the use of smaller generators and cabling.
  • Generator compatible
    It ensures clean, uninterrupted power to protected equipment when generator power is used.
  • Cold-start capable
    It provides temporary battery power when the utility power is out.
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment. UL, FCC, CE, C-Tick approvals.
APC Smart-UPS RT 2000 - UPS - 1.4 kW - 2000 VA
UPS - external
Rack Size
2U
25 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
1.4 kW / 2000 VA
Input Connectors
3 x power IEC 60320 C20, power BS 1363, power CEE 7/7
Output connectors
6 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Plug-in module
Run Time (Up To)
4.1 min at full load
43 cm x 48 cm x 9 cm
UPS - external
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
On-line
Supported Battery Technology
Lead Acid
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 280 V
Input Voltage Range (Adjustable)
AC 100 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 5% - 50/60 Hz
Power Capacity
1.4 kW / 2000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
420 joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
Recharge Time
4 hours
1 x management (RS-232) - 9 pin D-Sub (DB-9)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external
Audible alarm
C-Tick, ISO 9001, GOST, EN 60950, EN 61000-3-2, PCBC, UL 1449, VDE, EN55022 Class A, ISO 14001
Software Included
Drivers & Utilities, APC PowerChute plus, APC PowerChute Business Edition
Min Storage Temperature
-20 °C
Max Storage Temperature
50 °C
0 - 95%
Humidity Range Storage
0 - 95%
43 cm
48 cm
9 cm
25 kg
Resources
The following resources are available for the APC Smart-UPS RT- 2000VA/1400W
