APC Smart-UPS RT- 1000VA/700W
Quicklinx: 53SYWS00 Mfr#: SURT1000XLI
Type: UPS
Power Rating: 700Watt
£881.63 ex VAT
£1,057.95 inc VAT
Smart-UPS RT is a family of high performance UPSs for servers, networking equipment, telecommunication systems, industrial and medical equipment, and other mission-critical applications. Smart-UPS RT UPSs are based on the field-proven, industry-leading Smart-UPS functionality, but feature double conversion on-line topology, which delivers tight voltage and frequency regulation, zero transfer time to and from battery, and input power factor correction. While offering advanced performance and high availability features, the Smart-UPS RT can be managed using PowerChute software, as well as an array of SmartSlot accessories. Smart-UPS RT provides battery back up to the load through the use of internal batteries. However, an unlimited number of external battery packs can be added to meet desired levels of runtime. All Smart-UPS RTs and battery packs ship in tower configuration, while easily converting to the 19" rack-mount mode with the addition of an APC Rail Kit.
APC Smart-UPS RT 1000 - UPS - 700 Watt - 1000 VA
UPS - external
Rack Size
2U
23 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
700 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Plug-in module
Run Time (Up To)
10.2 min at full load
43 cm x 48 cm x 9 cm
UPS - external
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
UPS Technology
On-line
Supported Battery Technology
Lead Acid
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 280 V
Input Voltage Range (Adjustable)
AC 100 - 280 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 5% - 50/60 Hz
Power Capacity
700 Watt / 1000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
420 Joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
Recharge Time
3 hours
1 x management (RS-232) - 9 pin D-Sub (DB-9)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external
Audible alarm
C-Tick, ISO 9001, GOST, EN 60950, EN 61000-3-2, PCBC, UL 1449, VDE, EN55022 Class A, ISO 14001
Software Included
Drivers & Utilities, APC PowerChute plus, APC PowerChute Business Edition
Min Storage Temperature
-20 °C
Max Storage Temperature
50 °C
0 - 95%
Humidity Range Storage
0 - 95%
43 cm
48 cm
9 cm
23 kg
53SY APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £31.01
53SY APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £51.08
53SY APC Basic Rack-Mount PDU - power distribution strip In Stock £205.11
53SY APC 1U Vertical Cable Organiser In Stock £126.54
53SY APC 1U Horizontal Cable Organiser In Stock £56.75
53SY APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.78
53SY APC Netshelter heavy duty shelf In Stock £143.02
53SY APC - rack cable guide - 1U In Stock £52.84
53SY APC Rack PDU Basic Zero U 16A 208/230V In Stock £298.65
53SY APC 2-Post Mounting Kit for Smart-UPS In Stock £175.68
53SY APC Rack PDU Basic Zero U 32A 230V In Stock £325.48
53SY APC Temperature and Humidity Sensor In Stock £133.36
53SY APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £288.08
53SY APC Cable Managers (Qty 10) In Stock £37.21
53SY APC 2G Power distribution strip In Stock £646.62
53SY APC Rack PDU 2G METERED ZEROU In Stock £716.89
53SY APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £509.59
53SY APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,000.79
53SY APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £982.07
53SY APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.93
53SY APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,510.85
53SY APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £59.41
53SY APC 1U Blanking Panel Kit In Stock £35.63
53SY APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £57.04
53SY APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £49.22
53SY APC Power Cable (pack of 6) 1.22m In Stock £89.19
53SY APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,665.73
53SY APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.70
53SY APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £131.73
53SY APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £105.31
53SY APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £637.60
53SY APC Extended Warranty Service Pack 3 Year In Stock £164.21
53SY APC Metered Rack PDU In Stock £847.72
53SY APC Switched Rack PDU AC 208-230 V Ethernet In Stock £765.04
53SY APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £274.05
53SY APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,096.40
53SY APC Service Pack 1 Year Warranty Extension In Stock £80.40
53SY APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.15
53SY APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £687.96
53SY APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,259.02
53SY APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,309.03
53SY APC Rack PDU Basic 0U/1U 100-240V/ In Stock £83.64
53SY APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £470.78
Resources
The following resources are available for the APC Smart-UPS RT- 1000VA/700W
Type: UPS
Brand: APC
Price Range Ex VAT: £750 - £1000
