Smart-UPS RT is a family of high performance UPSs for servers, networking equipment, telecommunication systems, industrial and medical equipment, and other mission-critical applications. Smart-UPS RT UPSs are based on the field-proven, industry-leading Smart-UPS functionality, but feature double conversion on-line topology, which delivers tight voltage and frequency regulation, zero transfer time to and from battery, and input power factor correction. While offering advanced performance and high availability features, the Smart-UPS RT can be managed using PowerChute software, as well as an array of SmartSlot accessories. Smart-UPS RT provides battery back up to the load through the use of internal batteries. However, an unlimited number of external battery packs can be added to meet desired levels of runtime. All Smart-UPS RTs and battery packs ship in tower configuration, while easily converting to the 19" rack-mount mode with the addition of an APC Rail Kit.
- APC Smart-UPS RT 1000 - UPS - 700 Watt - 1000 VA
- UPS - external
- Rack Size
- 2U
- 23 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 220/230/240 V ± 5%
- Power Capacity
- 700 Watt / 1000 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 6 x power IEC 60320 C13
- Battery
- Lead Acid
- Battery Form Factor
- Plug-in module
- Run Time (Up To)
- 10.2 min at full load
- Black
- 43 cm x 48 cm x 9 cm
- 2-year warranty
- UPS - external
- Battery Enclosure Type
- Plug-in module
- Height (Rack Units)
- 2U
- Black
- UPS Technology
- On-line
- Supported Battery Technology
- Lead Acid
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 160 - 280 V
- Input Voltage Range (Adjustable)
- AC 100 - 280 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V ± 5% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 420 Joules
- Circuit Protection
- Circuit breaker
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 3 hours
- 1 x management (RS-232) - 9 pin D-Sub (DB-9)
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- Serial cable - external
- Audible alarm
- C-Tick, ISO 9001, GOST, EN 60950, EN 61000-3-2, PCBC, UL 1449, VDE, EN55022 Class A, ISO 14001
- Software Included
- Drivers & Utilities, APC PowerChute plus, APC PowerChute Business Edition
- Limited warranty - 2 years
- 0 °C
- 40 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 50 °C
- 0 - 95%
- Humidity Range Storage
- 0 - 95%
- 43 cm
- 48 cm
- 9 cm
- 23 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £30.95 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £204.36 |
APC 1U Horizontal Cable Organiser | In Stock | £56.61 |
APC Netshelter heavy duty shelf | In Stock | £144.25 |
APC Rack PDU, Basic, Zero U, 10A,2 | In Stock | £280.19 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £303.36 |
APC 2-Post Mounting Kit for Smart-UPS | In Stock | £178.79 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £329.44 |
APC Temperature and Humidity Sensor | In Stock | £133.03 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £300.02 |
APC Cable Managers (Qty 10) | In Stock | £37.12 |
APC 2G Power distribution strip | In Stock | £648.80 |
APC Rack PDU 2G METERED ZEROU | In Stock | £706.28 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £1,021.49 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £979.84 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,507.44 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £59.45 |
APC 1U Blanking Panel Kit | In Stock | £35.50 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.75 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £49.71 |
APC Power Cable (pack of 6) 1.22m | In Stock | £90.64 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,754.51 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £70.53 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £133.14 |
APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £105.31 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £643.09 |
APC Extended Warranty Service Pack 3 Year | In Stock | £163.86 |
APC Metered Rack PDU | In Stock | £880.85 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £762.02 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,118.18 |
APC Service Pack 1 Year Warranty Extension | In Stock | £81.21 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £62.64 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £686.60 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,286.82 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £164.54 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,333.77 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £85.11 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £466.49 |
