APC Smart-UPS RM 1000VA USB & Serial - UPS - 640 Watt - 1000 VA
Quicklinx: 4CW1WS00 Mfr#: SUA1000RMI1U
Type: UPS
Power Rating: 640Watt
£853.82 ex VAT
£1,024.58 inc VAT
APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATM's. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
With included PowerChute management software for servers and workstations, IT administrators can provide safe system shutdown and advanced UPS management (all major operating systems are supported). Connectivity is through serial or USB port (USB not standard on all models). Additional manageability is available through the SmartSlot, an internal accessory slot that allows you to install optional accessories to enhance the performance of your UPS. Network connection with Web browser management and/or environmental monitoring, serial port expansion, and out-of-band management options are available. With pure sine-wave output ensuring compatibility with all connected devices, Intelligent Battery Management ensuring a highly available UPS and an advanced 16 segment bar graph display ensuring information and management, the Smart-UPS is a UPS you can count on.
  • Front-access servicing
    Simplifies installation and UPS maintenance while minimizing space requirements.
  • USB connectivity
    USB compatibility and connectivity ensures quick and easy installation of the free PowerChute Personal Edition Software.
UPS - rack-mountable
Rack Size
1U
22 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V
Power Capacity
640 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13
Lead Acid
Run Time (Up To)
5.4 min at full load
43 cm x 66 cm x 4 cm
P/N: AR3003, AR3003SP, AR3006, AR3006SP, AR3103, AR3103SP, AR3106, AR3106SP, AR3140G, AR3340G, AR3357X674, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, NBWL0356A
Height (Rack Units)
1U
UPS Technology
Line interactive
Supported Battery Technology
Lead Acid
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V
Power Capacity
640 Watt / 1000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Lead Acid
Run Time (Up To)
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (USB) - 4 pin USB Type B
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external , USB cable - external
Rack Mounting Kit
Included
LED display, audible alarm
C-Tick, GOST, PCBC, UL 1449, VDE
Software Included
APC PowerChute Business Edition
Limited warranty - parts and labour - 2 years
Min Storage Temperature
-15 °C
Max Storage Temperature
45 °C
0 - 95%
Humidity Range Storage
0 - 95%
43 cm
66 cm
4 cm
22 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3003, AR3003SP, AR3006, AR3006SP, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103, AR3103SP, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, AR3810, AR3812, AR3814, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, NBWL0356A
4CW1 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £28.19
4CW1 APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £49.31
4CW1 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £52.40
4CW1 APC NETSHELTER SX 24U In Stock £1,143.96
4CW1 APC Temperature and Humidity Sensor In Stock £133.44
4CW1 APC Power Cable (pack of 6) 1.22m In Stock £85.46
4CW1 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £130.23
4CW1 APC Extended Warranty Service Pack 3 Year In Stock £151.33
4CW1 APC Service Pack 1 Year Warranty Extension In Stock £72.51
4CW1 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.82
4CW1 APC Switched PDU 10A 0U C13x16 In Stock £1,132.04
4CW1 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £653.11
4CW1 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £465.61
Resources
The following resources are available for the APC Smart-UPS RM 1000VA USB & Serial - UPS - 640 Watt - 1000 VA
Type: UPS
Brand: APC
Price Range Ex VAT: £750 - £1000
