APC Smart-UPS C LCD AC 230 V - 900 Watt - 1500VA USB
Quicklinx: DRTTWS00 Mfr#: SMC1500IC
Type: UPS
Power Rating: 900Watt
More than 50 In Stock
£590.91 ex VAT
£709.09 inc VAT
APC Smart-UPS C 1500VA LCD. AC 230 V, 900 Watt, 1500 VA ,USB output connectors: 8. In black with APC SmartConnect.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • LCD Status Display
    Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services
APC Smart-UPS C 1500VA LCD - UPS - 900 Watt - 1500 VA - with APC SmartConnect
UPS - external
24.09 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
900 Watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13
Lead Acid
Batteries Qty
1
Run Time (Up To)
4 min at full load
USB
17.1 cm x 43.9 cm x 21.9 cm
Bundled with
APC SmartConnect
UPS - external
Bundled with
APC SmartConnect
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 180 - 287 V
Input Voltage Range (Adjustable)
AC 170 - 300 V
Frequency Provided
50/60 Hz ± 3Hz
Frequency Required
50/60 Hz ± 3%
Input Connectors
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
900 Watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
4 min at full load , 11 min at half load
Recharge Time
3 hours
Transfer Time
6 ms
Maintenance free, sealed, leak-proof
Remote Management Interface
USB
1 x management - RJ-45 , 1 x USB - 4 pin USB Type A
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic shut down reset, automatic self-test, hot-swappable batteries, Green Function, auto restart, temperature-compensated battery charging
CSA, C-Tick, GOST, UL 1778, VDE
Software Included
APC PowerChute Business Edition
0 - 95%
Sound Emission
45 dBA
17.1 cm
43.9 cm
21.9 cm
24.09 kg
Shipping Width
32.8 cm
Shipping Depth
59.5 cm
Shipping Height
37.6 cm
Shipping Weight
27.23 kg
DRTT APC Basic Rack-Mount PDU - power distribution strip In Stock £201.26
DRTT APC 1U Vertical Cable Organiser In Stock £122.27
DRTT APC 1U Horizontal Cable Organiser In Stock £54.65
DRTT APC Netshelter heavy duty shelf In Stock £142.40
DRTT APC BackUPS+SmartUPS 1000 Battery In Stock £210.19
DRTT APC - rack cable guide - 1U In Stock £51.50
DRTT APC Rack PDU Basic Zero U 16A 208/230V In Stock £295.87
DRTT APC Rack PDU Basic Zero U 32A 230V In Stock £319.25
DRTT APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £286.38
DRTT APC Cable Managers (Qty 10) In Stock £35.20
DRTT APC 2G Power distribution strip In Stock £643.06
DRTT APC Rack PDU 2G METERED ZEROU In Stock £687.07
DRTT APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £980.84
DRTT APC 19" Rack LCD Console In Stock £1,378.32
DRTT APC Fixed Shelf - 50lbs/23kg, Black In Stock £80.63
DRTT APC NetShelter Zero U Accessory Mounting Bracket In Stock £66.81
DRTT APC 1U Blanking Panel Kit In Stock £34.57
DRTT APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.73
DRTT APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.09
DRTT APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,687.54
DRTT APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.74
DRTT APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £625.60
DRTT APC Extended Warranty Service Pack 3 Year In Stock £161.19
DRTT APC Metered Rack PDU In Stock £842.51
DRTT APC Switched Rack PDU AC 208-230 V Ethernet In Stock £743.24
DRTT APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £263.31
DRTT APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,073.90
DRTT APC Service Pack 1 Year Warranty Extension In Stock £73.29
DRTT APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £61.62
DRTT APC Switched PDU 10A 0U C13x16 In Stock £1,157.89
DRTT APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £668.24
DRTT APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,251.94
DRTT APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £160.96
DRTT APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,282.18
DRTT APC Rack PDU Basic 0U/1U 100-240V/ In Stock £81.63
DRTT APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £467.83
Type: UPS
Brand: APC
Price Range Ex VAT: £500 - £750
