APC Smart-UPS C 1500VA LCD. AC 230 V, 900 Watt, 1500 VA ,USB output connectors: 8. In black with APC SmartConnect.
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics -
Cold-start capable
Provides temporary battery power when the utility power is out -
LCD Status Display
Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection -
High online efficiency
Reduces utility costs, generates less heat -
SmartConnect
Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services
- APC Smart-UPS C 1500VA LCD - UPS - 900 Watt - 1500 VA - with APC SmartConnect
- UPS - external
- 24.09 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 900 Watt / 1500 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 8 x power IEC 60320 C13
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 4 min at full load
- Networking
- USB
- Black
- 17.1 cm x 43.9 cm x 21.9 cm
- 2-year warranty
- Bundled with
- APC SmartConnect
- UPS - external
- Black
- Bundled with
- APC SmartConnect
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 180 - 287 V
- Input Voltage Range (Adjustable)
- AC 170 - 300 V
- Frequency Provided
- 50/60 Hz ± 3Hz
- Frequency Required
- 50/60 Hz ± 3%
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 5% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 459 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 4 min at full load , 11 min at half load
- Recharge Time
- 3 hours
- Transfer Time
- 6 ms
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- USB
- 1 x management - RJ-45 , 1 x USB - 4 pin USB Type A
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic shut down reset, automatic self-test, hot-swappable batteries, Green Function, auto restart, temperature-compensated battery charging
- CSA, C-Tick, GOST, UL 1778, VDE
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 45 dBA
- 17.1 cm
- 43.9 cm
- 21.9 cm
- 24.09 kg
- Shipping Width
- 32.8 cm
- Shipping Depth
- 59.5 cm
- Shipping Height
- 37.6 cm
- Shipping Weight
- 27.23 kg
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £202.99 |
APC 1U Vertical Cable Organiser | In Stock | £125.65 |
APC 1U Horizontal Cable Organiser | In Stock | £56.36 |
APC Netshelter heavy duty shelf | In Stock | £143.23 |
APC BackUPS+SmartUPS 1000 Battery | In Stock | £213.88 |
APC - rack cable guide - 1U | In Stock | £52.48 |
APC Rack PDU, Basic, Zero U, 10A,2 | In Stock | £278.94 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £304.75 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £330.96 |
APC Cable Managers (Qty 10) | In Stock | £36.96 |
APC Rack PDU 2G METERED ZEROU | In Stock | £700.76 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £1,016.87 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £975.40 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £81.29 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,500.64 |
APC 1U Blanking Panel Kit | In Stock | £35.33 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.64 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,706.21 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £70.21 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £647.17 |
APC Extended Warranty Service Pack 3 Year | In Stock | £163.57 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £758.58 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £267.53 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,097.15 |
APC Service Pack 1 Year Warranty Extension | In Stock | £80.84 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £61.68 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £672.44 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,277.30 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £163.54 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,327.76 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £83.25 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £465.66 |
