APC Smart-UPS C 1500VA 2U Rack mountable LCD 230V
Quicklinx: 9Z1FWS00 Mfr#: SMC1500I-2U
Type: UPS
Power Rating: 900Watt
£575.99 ex VAT
£691.18 inc VAT
Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Pure sine wave output on battery simulates utility power to provide a high degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. LCD status display provides key UPS status at a glance. Cold-start capable provides temporary battery power when the utility power is out. Temperature-compensated battery charging prolongs battery life by regulating the charge voltage according to battery temperature. Intelligent battery management maximizes battery performance, life, and reliability through intelligent, precision charging.
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • LCD Status Display
    Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS C 1500VA 2U LCD - UPS - 900 Watt - 1500 VA
UPS - rack-mountable
Rack Size
2U
28.64 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
900 Watt / 1500 VA
Input Connectors
1
Output connectors
4 x power IEC 60320 C13
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
9 min at full load
USB
43.2 cm x 45.7 cm x 8.9 cm
Battery Enclosure Type
Internal
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 180 - 287 V
Input Voltage Range (Adjustable)
AC 170 - 300 V
Frequency Provided
57 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
1
Output Voltage
AC 230 V ± 5% - 57 - 63 Hz
Power Capacity
900 Watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
31 min at half load , 9 min at full load
Recharge Time
3 hours
Remote Management Interface
USB
1 x management (USB) - 4 pin USB Type B
Power cable , USB cable - external
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic shut down reset, automatic self-test, hot-swappable batteries
C-Tick, GOST, UL 1449, VDE, RoHS, REACH
Software Included
Drivers & Utilities
Limited warranty - parts and labour - 2 years
0 - 95%
Sound Emission
46 dBA
43.2 cm
45.7 cm
8.9 cm
28.64 kg
Shipping Width
59.4 cm
Shipping Depth
60.3 cm
Shipping Height
25.1 cm
Shipping Weight
31.91 kg
9Z1F APC Basic Rack-Mount PDU - power distribution strip In Stock £199.36
9Z1F APC 1U Vertical Cable Organiser In Stock £121.12
9Z1F APC 1U Horizontal Cable Organiser In Stock £53.59
9Z1F APC Netshelter heavy duty shelf In Stock £141.84
9Z1F APC - rack cable guide - 1U In Stock £50.87
9Z1F APC Rackmount Rail Kit In Stock £90.51
9Z1F APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £203.79
9Z1F APC Rack PDU Basic Zero U 16A 208/230V In Stock £294.53
9Z1F APC Rack PDU Basic Zero U 32A 230V In Stock £312.30
9Z1F APC Equipment Support Rails for 600mm Wide Enclosure In Stock £72.21
9Z1F APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £284.90
9Z1F APC Cable Managers (Qty 10) In Stock £34.52
9Z1F APC 2G Power distribution strip In Stock £642.31
9Z1F APC Rack PDU 2G METERED ZEROU In Stock £673.80
9Z1F APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £962.02
9Z1F APC 19" Rack LCD Console In Stock £1,379.84
9Z1F APC Fixed Shelf - 50lbs/23kg, Black In Stock £80.86
9Z1F APC NetShelter Zero U Accessory Mounting Bracket In Stock £65.99
9Z1F APC Replacement Battery Cartridge #132 In Stock £275.97
9Z1F APC 1U Blanking Panel Kit In Stock £33.92
9Z1F APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £55.89
9Z1F APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £47.66
9Z1F APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.00
9Z1F APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £630.78
9Z1F APC Extended Warranty Service Pack 3 Year In Stock £152.13
9Z1F APC Metered Rack PDU In Stock £838.72
9Z1F APC Switched Rack PDU AC 208-230 V Ethernet In Stock £739.43
9Z1F APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £257.30
9Z1F APC Service Pack 1 Year Warranty Extension In Stock £72.51
9Z1F APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £59.64
9Z1F APC Switched PDU 10A 0U C13x16 In Stock £1,159.17
9Z1F APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £653.11
9Z1F APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,245.58
9Z1F APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £157.34
9Z1F APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,270.23
9Z1F APC Rack PDU Basic 0U/1U 100-240V/ In Stock £82.70
9Z1F APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £465.61
Type: UPS
Brand: APC
Price Range Ex VAT: £500 - £750
