Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Pure sine wave output on battery simulates utility power to provide a high degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. LCD status display provides key UPS status at a glance. Cold-start capable provides temporary battery power when the utility power is out. Temperature-compensated battery charging prolongs battery life by regulating the charge voltage according to battery temperature. Intelligent battery management maximizes battery performance, life, and reliability through intelligent, precision charging.
High online efficiency
Reduces utility costs, generates less heat. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. -
LCD Status Display
Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs. -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Prolongs battery life by regulating the charge voltage according to battery temperature.
- APC Smart-UPS C 1500VA 2U LCD - UPS - 900 Watt - 1500 VA
- UPS - rack-mountable
- Rack Size
- 2U
- 28.64 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 900 Watt / 1500 VA
- Input Connectors
- 1
- Output connectors
- 4 x power IEC 60320 C13
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Run Time (Up To)
- 9 min at full load
- Networking
- USB
- Black
- 43.2 cm x 45.7 cm x 8.9 cm
- 2-year warranty
- Battery Enclosure Type
- Internal
- Height (Rack Units)
- 2U
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 180 - 287 V
- Input Voltage Range (Adjustable)
- AC 170 - 300 V
- Frequency Provided
- 57 - 63 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 5% - 57 - 63 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 459 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 31 min at half load , 9 min at full load
- Recharge Time
- 3 hours
- Remote Management Interface
- USB
- 1 x management (USB) - 4 pin USB Type B
- Cables Included
- Power cable , USB cable - external
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic shut down reset, automatic self-test, hot-swappable batteries
- C-Tick, GOST, UL 1449, VDE, RoHS, REACH
- Software Included
- Drivers & Utilities
- Limited warranty - parts and labour - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 46 dBA
- 43.2 cm
- 45.7 cm
- 8.9 cm
- 28.64 kg
- Shipping Width
- 59.4 cm
- Shipping Depth
- 60.3 cm
- Shipping Height
- 25.1 cm
- Shipping Weight
- 31.91 kg
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £197.72 |
APC 1U Vertical Cable Organiser | In Stock | £119.92 |
APC 1U Horizontal Cable Organiser | In Stock | £53.60 |
APC Netshelter heavy duty shelf | In Stock | £137.58 |
APC - rack cable guide - 1U | In Stock | £48.46 |
APC Rackmount Rail Kit | In Stock | £88.02 |
APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT | In Stock | £203.71 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £286.90 |
APC 2-Post Mounting Kit for Smart-UPS | In Stock | £169.50 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £311.94 |
APC Equipment Support Rails for 600mm Wide Enclosure | In Stock | £71.30 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £271.25 |
APC Cable Managers (Qty 10) | In Stock | £34.52 |
APC 2G Power distribution strip | In Stock | £622.55 |
APC Rack PDU 2G METERED ZEROU | In Stock | £671.97 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £962.24 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £953.12 |
APC 19" Rack LCD Console | In Stock | £1,344.09 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £76.76 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,463.26 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £64.11 |
APC Replacement Battery Cartridge #132 | In Stock | £273.34 |
APC 1U Blanking Panel Kit | In Stock | £33.82 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £54.39 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,602.33 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £614.64 |
APC Extended Warranty Service Pack 3 Year | In Stock | £146.46 |
APC Metered Rack PDU | In Stock | £817.13 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £731.73 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £263.29 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,023.33 |
APC Service Pack 1 Year Warranty Extension | In Stock | £69.24 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £59.34 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,129.15 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £668.72 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,217.48 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £155.82 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £80.21 |
