APC Smart-UPS C 1500VA 2U LCD - UPS (rack-mountable)
Quicklinx: DJKJWS00 Mfr#: SMC1500I-2UC
Type: UPS
Power Rating: 900Watt
Hurry, only 1 left in stock!
£740.28 ex VAT
£888.33 inc VAT
Express delivery Order within the next 21 hours for delivery on Friday
APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATMs. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services.
  • Software package
    SmartConnect software for remote power monitoring feature availability varies by terms of use
  • Communication port support
    SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • LCD Status Display
    Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS C SMC1500I-2UC - UPS - 900 Watt - 1500 VA - with APC SmartConnect
UPS - rack-mountable
Rack Size
2U
28.64 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 230 V ± 5%
Power Capacity
900 Watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13 , 2 x IEC jumper
Lead Acid
Batteries Qty
1
Run Time (Up To)
10.1 min at full load
RS-232, USB
43.2 cm x 47.7 cm x 8.6 cm
Bundled with
APC SmartConnect
Height (Rack Units)
2U
Bundled with
APC SmartConnect
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 180 - 287 V
Input Voltage Range (Adjustable)
AC 170 - 300 V
Frequency Provided
50/60 Hz ± 3Hz
Frequency Required
50/60 Hz ± 3Hz
Input Connectors
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
900 Watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
10.1 min at full load , 25 min at half load , 173 min at 50 Watts , 107 min at 100 Watts , 59 min at 200 Watts , 39.2 min at 300 Watts , 28.6 min at 400 Watts , 22.1 min at 500 Watts , 17.6 min at 600 Watts , 14.4 min at 700 Watts , 12 min at 800 Watts , 10.1 min at 900 Watts
Recharge Time
3 hours
Maintenance free
Remote Management Interface
RS-232, USB
1 x management (USB) - 4 pin USB Type B , 1 x serial - RJ-45
Serial cable - external , USB cable - external
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic shut down reset, automatic self-test, hot-swappable batteries
CSA, C-Tick, GOST, UL 1778, VDE
Software Included
APC PowerChute Business Edition
Limited warranty - parts and labour - 2 years
0 - 95%
Sound Emission
46 dBA
43.2 cm
47.7 cm
8.6 cm
28.64 kg
Shipping Width
59.4 cm
Shipping Depth
60.3 cm
Shipping Height
25.1 cm
Shipping Weight
31.91 kg
DJKJ APC Basic Rack-Mount PDU - power distribution strip In Stock £200.45
DJKJ APC 1U Vertical Cable Organiser In Stock £121.77
DJKJ APC 1U Horizontal Cable Organiser In Stock £53.89
DJKJ APC BackUPS+SmartUPS 1000 Battery In Stock £209.34
DJKJ APC - rack cable guide - 1U In Stock £50.85
DJKJ APC Rackmount Rail Kit In Stock £90.24
DJKJ APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £204.87
DJKJ APC Rack PDU Basic Zero U 16A 208/230V In Stock £294.43
DJKJ APC Rack PDU Basic Zero U 32A 230V In Stock £321.56
DJKJ APC Equipment Support Rails for 600mm Wide Enclosure In Stock £72.61
DJKJ APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £286.39
DJKJ APC Cable Managers (Qty 10) In Stock £35.06
DJKJ APC 2G Power distribution strip In Stock £643.24
DJKJ APC Rack PDU 2G METERED ZEROU In Stock £684.31
DJKJ APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £977.00
DJKJ APC 19" Rack LCD Console In Stock £1,379.32
DJKJ APC Fixed Shelf - 50lbs/23kg, Black In Stock £80.83
DJKJ APC NetShelter Zero U Accessory Mounting Bracket In Stock £65.98
DJKJ APC 1U Blanking Panel Kit In Stock £34.11
DJKJ APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £55.88
DJKJ APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £47.91
DJKJ APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £68.98
DJKJ APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £634.07
DJKJ APC Extended Warranty Service Pack 3 Year In Stock £154.30
DJKJ APC Metered Rack PDU In Stock £842.70
DJKJ APC Switched Rack PDU AC 208-230 V Ethernet In Stock £743.33
DJKJ APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £263.52
DJKJ APC Service Pack 1 Year Warranty Extension In Stock £72.91
DJKJ APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £61.02
DJKJ APC Switched PDU 10A 0U C13x16 In Stock £1,154.43
DJKJ APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £665.61
DJKJ APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,252.46
DJKJ APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £158.19
DJKJ APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,277.16
DJKJ APC Rack PDU Basic 0U/1U 100-240V/ In Stock £82.71
DJKJ APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £468.04
Type: UPS
Brand: APC
Price Range Ex VAT: £500 - £750
