APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATMs. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
SmartConnect
Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services. -
Software package
SmartConnect software for remote power monitoring feature availability varies by terms of use -
Communication port support
SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use -
High online efficiency
Reduces utility costs, generates less heat. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. -
LCD Status Display
Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs. -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature.
- APC Smart-UPS C SMC1500I-2UC - UPS - 900 Watt - 1500 VA - with APC SmartConnect
- UPS - rack-mountable
- Rack Size
- 2U
- 28.64 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 900 Watt / 1500 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 4 x power IEC 60320 C13 , 2 x IEC jumper
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 10.1 min at full load
- Networking
- RS-232, USB
- Black
- 43.2 cm x 47.7 cm x 8.6 cm
- 2-year warranty
- Bundled with
- APC SmartConnect
- Height (Rack Units)
- 2U
- Black
- Bundled with
- APC SmartConnect
- UPS Technology
- Line interactive
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 180 - 287 V
- Input Voltage Range (Adjustable)
- AC 170 - 300 V
- Frequency Provided
- 50/60 Hz ± 3Hz
- Frequency Required
- 50/60 Hz ± 3Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 5% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 459 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 10.1 min at full load , 25 min at half load , 173 min at 50 Watts , 107 min at 100 Watts , 59 min at 200 Watts , 39.2 min at 300 Watts , 28.6 min at 400 Watts , 22.1 min at 500 Watts , 17.6 min at 600 Watts , 14.4 min at 700 Watts , 12 min at 800 Watts , 10.1 min at 900 Watts
- Recharge Time
- 3 hours
- Maintenance free
- Remote Management Interface
- RS-232, USB
- 1 x management (USB) - 4 pin USB Type B , 1 x serial - RJ-45
- Cables Included
- Serial cable - external , USB cable - external
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic shut down reset, automatic self-test, hot-swappable batteries
- CSA, C-Tick, GOST, UL 1778, VDE
- Software Included
- APC PowerChute Business Edition
- Limited warranty - parts and labour - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 46 dBA
- 43.2 cm
- 47.7 cm
- 8.6 cm
- 28.64 kg
- Shipping Width
- 59.4 cm
- Shipping Depth
- 60.3 cm
- Shipping Height
- 25.1 cm
- Shipping Weight
- 31.91 kg
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £204.04 |
APC 1U Vertical Cable Organiser | In Stock | £124.32 |
APC 1U Horizontal Cable Organiser | In Stock | £56.47 |
APC Netshelter heavy duty shelf | In Stock | £142.27 |
APC BackUPS+SmartUPS 1000 Battery | In Stock | £210.36 |
APC - rack cable guide - 1U | In Stock | £52.59 |
APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT | In Stock | £205.61 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £297.10 |
APC 2-Post Mounting Kit for Smart-UPS | In Stock | £174.76 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £323.79 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £286.58 |
APC Cable Managers (Qty 10) | In Stock | £37.03 |
APC 2G Power distribution strip | In Stock | £643.25 |
APC Rack PDU 2G METERED ZEROU | In Stock | £713.44 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 | In Stock | £506.92 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £995.56 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £977.33 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £81.50 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,503.58 |
APC 1U Blanking Panel Kit | In Stock | £35.46 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.75 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.98 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,710.64 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £70.36 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £634.28 |
APC Extended Warranty Service Pack 3 Year | In Stock | £163.36 |
APC Metered Rack PDU | In Stock | £843.29 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £761.37 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,090.67 |
APC Service Pack 1 Year Warranty Extension | In Stock | £79.99 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £61.84 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £698.02 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,252.44 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,302.20 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £83.21 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £468.32 |
