SmartConnect
Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services. -
Software package
SmartConnect software for remote power monitoring feature availability varies by terms of use -
Communication port support
SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use -
High online efficiency
Reduces utility costs, generates less heat. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. -
LCD Status Display
Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs. -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature.
- APC Smart-UPS C - UPS - 600 Watt - 1000 VA - with APC SmartConnect
- UPS - rack-mountable
- Rack Size
- 2U
- 20.52 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 600 Watt / 1000 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Battery
- Lead Acid
- Batteries Qty
- 1
- Networking
- USB, serial
- Black
- 43.2 cm x 40.6 cm x 8.9 cm
- 2-year warranty
- Bundled with
- APC SmartConnect
- Designed For
- P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150W, AR3155SP, AR3155W, AR3300W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
- Height (Rack Units)
- 2U
- Black
- Bundled with
- APC SmartConnect
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 180 - 287 V
- Input Voltage Range (Adjustable)
- AC 170 - 300 V
- Frequency Provided
- 57 - 63 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Output Voltage
- AC 230 V ± 5% - 57 - 63 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 459 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 16 min at half load , 6 min at full load
- Recharge Time
- 3 hours
- Remote Management Interface
- USB, serial
- Cables Included
- Power cable , USB cable - external
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic shut down reset, automatic self-test, hot-swappable batteries
- C-Tick, GOST, UL 1449, VDE, RoHS, REACH
- Software Included
- APC PowerChute Business Edition
- Limited warranty - parts and labour - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 42 dBA
- 43.2 cm
- 40.6 cm
- 8.9 cm
- 20.52 kg
- Shipping Width
- 59.4 cm
- Shipping Depth
- 58.4 cm
- Shipping Height
- 24.1 cm
- Shipping Weight
- 22.33 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR100, AR100HD, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X432, AR7007, AR7050, AR7057, NBWL0356A
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £28.19 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £49.31 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £199.36 |
APC 1U Vertical Cable Organiser | In Stock | £121.12 |
APC 1U Horizontal Cable Organiser | In Stock | £52.33 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £52.40 |
APC Netshelter heavy duty shelf | In Stock | £141.84 |
APC - rack cable guide - 1U | In Stock | £50.67 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £293.40 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £312.30 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £285.33 |
APC Cable Managers (Qty 10) | In Stock | £34.52 |
APC 2G Power distribution strip | In Stock | £639.87 |
APC Rack PDU 2G METERED ZEROU | In Stock | £673.83 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £962.06 |
APC 19" Rack LCD Console | In Stock | £1,374.58 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £80.55 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £65.74 |
APC 1U Blanking Panel Kit | In Stock | £33.92 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £55.68 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £47.66 |
APC Power Cable (pack of 6) 1.22m | In Stock | £85.46 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £68.75 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £130.23 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £630.78 |
APC Metered Rack PDU | In Stock | £838.72 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £726.46 |
APC 1 Year Extended Warranty 2015-4037 | In Stock | £60.63 |
APC Service Pack 3 Year Warranty Extension | In Stock | £106.69 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £59.64 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,132.04 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £653.11 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,248.14 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £157.34 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £82.70 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £465.61 |
