APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATMs. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
SmartConnect
Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services. -
Software package
SmartConnect software for remote power monitoring feature availability varies by terms of use -
Communication port support
SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use -
High online efficiency
Reduces utility costs, generates less heat. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Energy meter
Provides actual kilowatt hours of usage for energy conscious users. -
Predictive replace battery date
Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning. -
Intuitive LCD interface
Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys. -
Single switched outlet group
Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding. -
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Intelligent Card Slot
Customize UPS capabilities with management cards. -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature.
 - APC Smart-UPS 750VA LCD RM - UPS - 500 Watt - 750 VA
 - UPS - rack-mountable
- Rack Size
 - 2U
 - 21.23 kg
- Input Voltage
 - AC 230 V
- Output Voltage
 - AC 230 V
- Power Capacity
 - 500 Watt / 750 VA
- Input Connectors
 - 1 x power IEC 60320 C14
- Output connectors
 - 4 x power IEC 60320 C13 , 2 x IEC jumper
- Battery
 - Lead Acid
- Run Time (Up To)
 - 6 min at full load
- Networking
 - Ethernet, RS-232, USB
 - Black
 - 43.2 cm x 40.9 cm x 8.6 cm
- Designed For
 - P/N: AR2487G, AR3100W, AR3103SP, AR3105SP, AR3105W, AR3106SP, AR3140G, AR3140W, AR3150W, AR3155W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
- Height (Rack Units)
 - 2U
 - Black
- UPS Technology
 - Line interactive
- Input Voltage
 - AC 230 V
- Input Voltage Range
 - AC 160 - 286 V
- Input Voltage Range (Adjustable)
 - AC 150 - 300 V
- Frequency Provided
 - 50/60 Hz
- Frequency Required
 - 50/60 Hz ± 3Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
 - AC 230 V 50/60 Hz
- Power Capacity
 - 500 Watt / 750 VA
- Output Waveform
 - Sinewave
- Surge Suppression
- Technology
 - Lead Acid
- Run Time (Up To)
 - 6 min at full load , 5 min at 500 Watts , 24 min at 200 Watts
- Recharge Time
 - 3 hours
 - Maintenance free, sealed, leak-proof
- Remote Management Interface
 - 1 x management (RS-232) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , Management (Ethernet) - RJ-45
- Expansion Slots
 - 1 (total) / 1 (free) x SmartSlot
 - Automatic Voltage Regulation (AVR), LCD display, audible alarm, energy metre, LED indicators
 - VDE, EN 62040-2, RCM, EN 62040-1
- Software Included
 - APC PowerChute Business Edition
 - 0 °C
 - 40 °C
 - 0 - 95%
- Sound Emission
 - 42 dBA
 - 43.2 cm
 - 40.9 cm
 - 8.6 cm
 - 21.23 kg
- Designed For
 - P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF002, ACF102BLK, ACF400, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR100, AR100HD, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103SP, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X432, AR7050, NBWL0356A
                        APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £30.69 |
                        APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £53.98 |
                        APC Temperature and Humidity Sensor | In Stock | £134.43 |
                        APC Replacement Battery Cartridge # 123 | In Stock | £87.15 |
                        APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £58.29 |
                        APC Power Cable (pack of 6) 1.22m | In Stock | £88.25 |
                        APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £131.99 |
                        APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £102.54 |
                        APC 1 Year Extended Warranty 2015-4037 | In Stock | £62.86 |
                        APC Service Pack 3 Year Warranty Extension | In Stock | £117.04 |
                        APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £674.28 |
                        APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £472.06 |
