APC Smart-UPS 750VA RM 230V SmartConnect
Quicklinx: FJ55WS00 Mfr#: SMT750RMI2UC
Power Rating: 500Watt, 500Watt
47 In Stock
£536.25 ex VAT
£643.50 inc VAT
APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATMs. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services.
  • Software package
    SmartConnect software for remote power monitoring feature availability varies by terms of use
  • Communication port support
    SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Intelligent Card Slot
    Customize UPS capabilities with management cards.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS 750VA LCD RM - UPS - 500 Watt - 750 VA
UPS - rack-mountable
Rack Size
2U
21.23 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
500 Watt / 750 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13 , 2 x IEC jumper
Lead Acid
Run Time (Up To)
6 min at full load
Ethernet, RS-232, USB
43.2 cm x 40.9 cm x 8.6 cm
P/N: AR2487G, AR3100W, AR3103SP, AR3105SP, AR3105W, AR3106SP, AR3140G, AR3140W, AR3150W, AR3155W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 150 - 300 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz ± 3Hz
Input Connectors
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
500 Watt / 750 VA
Output Waveform
Sinewave
Surge Suppression
Lead Acid
Run Time (Up To)
6 min at full load , 5 min at 500 Watts , 24 min at 200 Watts
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (RS-232) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , Management (Ethernet) - RJ-45
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Automatic Voltage Regulation (AVR), LCD display, audible alarm, energy metre, LED indicators
VDE, EN 62040-2, RCM, EN 62040-1
Software Included
APC PowerChute Business Edition
0 - 95%
Sound Emission
42 dBA
43.2 cm
40.9 cm
8.6 cm
21.23 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF002, ACF102BLK, ACF400, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR100, AR100HD, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103SP, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X432, AR7050, NBWL0356A
FJ55 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.69
FJ55 APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £49.41
FJ55 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.98
FJ55 APC 2-Post Mounting Kit for Smart-UPS In Stock £175.84
FJ55 APC Temperature and Humidity Sensor In Stock £134.43
FJ55 APC Replacement Battery Cartridge # 123 In Stock £87.15
FJ55 APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £58.29
FJ55 APC Power Cable (pack of 6) 1.22m In Stock £88.25
FJ55 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £131.99
FJ55 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £102.54
FJ55 APC 1 Year Extended Warranty 2015-4037 In Stock £62.86
FJ55 APC Service Pack 3 Year Warranty Extension In Stock £117.04
FJ55 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.99
FJ55 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £674.28
FJ55 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £472.06
Brand: APC
Price Range Ex VAT: £500 - £750
