APC Smart-UPS 750VA LCD 230V
Quicklinx: 76D3WS00 Mfr#: SMT750I
APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATMs. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning
  • SmartSlot
    Customize UPS capabilities with management cards
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users
APC Smart-UPS 750 LCD - UPS - 500 Watt - 750 VA
UPS - external
13.18 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
500 Watt / 750 VA
Input Connectors
Power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13
Lead Acid
Run Time (Up To)
5 min at full load
RS-232, USB
13.8 cm x 36.3 cm x 16.1 cm
3-year warranty
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 280 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
47 - 53 / 57-63 Hz
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 230 V 47 - 53 / 57-63 Hz
Power Capacity
500 Watt / 750 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
540 Joules
Lead Acid
Run Time (Up To)
5 min at full load
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x USB
Expansion Slots
1 SmartSlot
Audible alarm, LCD display
C-Tick, UL 1449, VDE, EN 50091-2, RoHS, EN 50091-1, REACH
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
40 dBA
13.8 cm
36.3 cm
16.1 cm
13.18 kg
76D3 APC APC Legacy Communications Card In Stock £42.71
