APC Smart-UPS 750VA LCD 230V
Quicklinx: 76D3WS00 Mfr#: SMT750I
Type: UPS
Power Rating: 500Watt, 500Watt
£337.04 ex VAT
£404.44 inc VAT
APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATMs. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Intelligent Card Slot
    Customize UPS capabilities with management cards.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS 750 LCD - UPS - 500 Watt - 750 VA
UPS - external
13.18 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
500 Watt / 750 VA
Input Connectors
Power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13 , 2 x IEC jumper
Lead Acid
Run Time (Up To)
5 min at full load
RS-232, USB
13.8 cm x 36.3 cm x 16.1 cm
3-year warranty
P/N: AR4000MVX429, AR4000MVX432, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 280 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
47 - 53 / 57 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 230 V 47 - 53 / 57 - 63 Hz
Power Capacity
500 Watt / 750 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
540 Joules
Lead Acid
Run Time (Up To)
5 min at full load
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x USB
Expansion Slots
1 SmartSlot
Audible alarm, LCD display
C-Tick, UL 1449, VDE, EN 50091-2, RoHS, EN 50091-1, REACH
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
40 dBA
13.8 cm
36.3 cm
16.1 cm
13.18 kg
P/N: AR4000MV, AR4000MVX429, AR4000MVX432, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432
76D3 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.69
76D3 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.98
76D3 APC Replacement Battery Cartridge #48 - UPS battery In Stock £140.76
76D3 APC Temperature and Humidity Sensor In Stock £134.43
76D3 APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £58.29
76D3 APC Power Cable (pack of 6) 1.22m In Stock £88.25
76D3 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £131.99
76D3 APC 1 Year Extended Warranty 2015-4037 In Stock £62.86
76D3 APC Service Pack 3 Year Warranty Extension In Stock £117.04
76D3 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.99
76D3 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £674.28
Type: UPS
Brand: APC
