APC Smart-UPS 750VA LCD 230V
Quicklinx: FRF5WS00 Mfr#: SMT750IC
Power Rating: 500Watt, 500Watt
More than 50 In Stock
£345.43 ex VAT
£414.51 inc VAT
Intelligent and efficient network power protection from entry level to scalable runtime. Ideal UPS for servers, point-of-sale, routers, switches, hubs and other network devices.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services.
  • SmartSlot
    Customize UPS capabilities with management cards.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS SMT750IC - UPS - 500 Watt - 750 VA - with APC SmartConnect
UPS - external
13.18 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 230 V ± 5%
Power Capacity
500 Watt / 750 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
6 x power IEC 60320 C13 , 2 x IEC jumper
Lead Acid
Batteries Qty
1
Run Time (Up To)
4.6 min at full load
RS-232, USB
13.8 cm x 35.81 cm x 15.75 cm
3-year warranty
Bundled with
APC SmartConnect
UPS - external
Bundled with
APC SmartConnect
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
50/60 Hz ± 3Hz
Frequency Required
50/60 Hz ± 3Hz
Input Connectors
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
500 Watt / 750 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
540 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
4.6 min at full load , 15.9 min at half load , 103 min at 50 Watts , 50.5 min at 100 Watts , 21.7 min at 200 Watts , 12 min at 300 Watts , 7.3 min at 400 Watts
Recharge Time
3 hours
Transfer Time
6 ms
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x management (RS-232) - RJ-45 , 1 x management (USB)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external , USB cable - external , Power cable 1.83 m
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic self-test, predicitive failure notification, hot-swappable batteries, energy metre
CSA, UL 1778, VDE, IEC 62040-2, RoHS, REACH, EN 62040-2, EAC, RCM, IEC 62040-1, EN 62040-1
Software Included
APC PowerChute Business Edition
Limited warranty - replace or repair - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
40 dBA
13.8 cm
35.81 cm
15.75 cm
13.18 kg
Shipping Width
27.8 cm
Shipping Depth
39.9 cm
Shipping Height
30.1 cm
Shipping Weight
14.23 kg
FRF5 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £29.80
FRF5 APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £49.58
FRF5 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £52.68
FRF5 APC Replacement Battery Cartridge #48 - UPS battery In Stock £139.38
FRF5 APC Temperature and Humidity Sensor In Stock £133.00
FRF5 APC Power Cable (pack of 6) 1.22m In Stock £86.79
FRF5 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £101.13
FRF5 APC 1 Year Extended Warranty 2015-4037 In Stock £62.16
FRF5 APC Service Pack 3 Year Warranty Extension In Stock £113.71
FRF5 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £61.13
FRF5 APC Switched PDU 10A 0U C13x16 In Stock £1,123.97
FRF5 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £657.20
FRF5 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £469.02
Brand: APC
