APC Smart-UPS 5000VA
Quicklinx: 52W9WS00 Mfr#: SUA5000RMI5U
Type: UPS
Power Rating: 4kW
10 In Stock
£3,733.92 ex VAT
£4,480.70 inc VAT
APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATMs. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced
  • Resettable circuit breakers
    Enables a quick recovery from overload events
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • SmartSlot
    Customize UPS capabilities with management cards
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment
  • Network manageable
    Provides remote power management of the UPS over the network
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Boost and Trim Automatic Voltage Regulation (AVR)
    Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models)
  • Serial connectivity
    Provides management of the UPS via a serial port
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power
  • Adjustable voltage-transfer points
    Maximizes useful battery life by widening the input voltage window or tightening the output voltage regulation
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment
APC Smart-UPS - UPS - 4 kW - 5000 VA
UPS - external
Rack Size
5U
97.7 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
4 kW / 5000 VA
Input Connectors
1 x hardwire 3-wire
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid
Battery Form Factor
Internal
Batteries Qty
2
Run Time (Up To)
9.4 min at full load
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP
48.3 cm x 66 cm x 22.2 cm
P/N: AR2200, AR2280, AR2487G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3140G, AR3140W, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3340G, AR3340W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, AR4038IX432, NBWL0356A
UPS - external
Battery Enclosure Type
Internal
Height (Rack Units)
5U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x hardwire 3-wire
Output Voltage
AC 220/230/240 V ± 5% - 50/60 Hz
Power Capacity
4 kW / 5000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Quantity
2
Lead Acid
Run Time (Up To)
Recharge Time
3 hours
Remote Management Interface
SNMP, Telnet, HTTP
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (Ethernet) - RJ-45
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Serial cable - external
Rack Mounting Kit
Included
Audible alarm, LED indicators, noise filtering
C-Tick, GOST, GS, VDE, EN 50091-2, EN 50091-1
Software Included
APC PowerChute Business Edition
0 - 95%
Sound Emission
53 dBA
48.3 cm
66 cm
22.2 cm
97.7 kg
Shipping Width
61 cm
Shipping Depth
76.2 cm
Shipping Height
63.5 cm
Shipping Weight
107 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR2101, AR2102BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140G, AR3140W, AR3150, AR3150SP, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR3814, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
52W9 APC Basic Rack-Mount PDU - power distribution strip In Stock £202.03
52W9 APC 1U Vertical Cable Organiser In Stock £122.75
52W9 APC 1U Horizontal Cable Organiser In Stock £54.86
52W9 APC Netshelter heavy duty shelf In Stock £142.89
52W9 APC - rack cable guide - 1U In Stock £51.09
52W9 APC Rack PDU Basic Zero U 16A 208/230V In Stock £299.80
52W9 APC Replacement Battery Cartridge RBC55 In Stock £431.92
52W9 APC Rack PDU Basic Zero U 32A 230V In Stock £320.46
52W9 APC NETSHELTER SX 24U In Stock £1,134.35
52W9 APC Temperature and Humidity Sensor In Stock £133.14
52W9 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £287.81
52W9 APC Cable Managers (Qty 10) In Stock £35.34
52W9 APC Rack PDU 2G METERED ZEROU In Stock £689.69
52W9 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £984.76
52W9 APC 19" Rack LCD Console In Stock £1,385.59
52W9 APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.00
52W9 APC NetShelter Zero U Accessory Mounting Bracket In Stock £66.29
52W9 APC 1U Blanking Panel Kit In Stock £34.72
52W9 APC Service Pack 3 Year Warranty Extension (for new purchases) In Stock £527.73
52W9 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.13
52W9 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.30
52W9 APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,694.93
52W9 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.29
52W9 APC Extended Warranty Renewal Technical Support (Renewal) 3 Years In Stock £771.56
52W9 APC Metered Rack PDU In Stock £846.52
52W9 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £736.14
52W9 APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £264.70
52W9 APC Service Pack 1 Year Warranty Extension In Stock £240.13
52W9 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.44
52W9 APC Switched PDU 10A 0U C13x16 In Stock £1,164.00
52W9 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £671.74
52W9 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,258.20
52W9 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £162.29
52W9 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,287.30
52W9 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £81.93
52W9 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £470.30
Resources
Type: UPS
Power Rating: 4kW
Brand: APC
Price Range Ex VAT: £1500+
